Home > Maintenance & Modifications > Replacing rear anti roll bar bushes with arc system
RRS Daz
Is there a guide on here for replacing the rear anti roll bar bushes on the arc bar system??
I've been under the sport today and done the drop links but it looks really involved to do the anti roll bar bushes.
Anyone got a guide or tips or even special tools that make the job easier please tell.
The knocking a driving me crazy now.
Post #405909 Thu Dec 12 2013 6:29pm
RRS Daz
Anyone there Whistle
Post #406063 Fri Dec 13 2013 6:57pm
Paddi
Well there is this guide on the D3 site but I'm not sure if it is the same for ARC equipped vehicles.
http://www.disco3.co.uk/forum/topic51384.html 2008 MY Java Black TDV8 HSE
Post #406068 Fri Dec 13 2013 7:21pm
RRS Daz
^^^^^ thanks for the reply.
I'd found that link and have read it.
It's more what tool is best to get to the bolts holding the bushes in place?? It seems it has less space than the link provided.
Post #406077 Fri Dec 13 2013 9:10pm
Disco_Mikey
Replied to your PM Thumbs Up
The ARC system is completely different to that of the D3. TDV6 is much easier than the TDV8, but you dont "NEED" the special tools to do the job Thumbs Up
Post #406094 Fri Dec 13 2013 10:53pm
RRS Daz
Well that's good not needing the special tool but I won't help with my shovel hands Rolling with laughter
Thanks very much for the reply.
I've read that dropping the rear diff out of the way with the 3 x 24mm bolts then bar it out of way for better access is a good start.
Post #406095 Fri Dec 13 2013 11:05pm
Disco_Mikey
Crossed wires, methinks Embarassed
Special tools are for the front ARC bushes Thumbs Up
Rear bushes are exactly the same procedure as D3 rear, though with different bushes.
Don't touch the rear diff Thumbs Up
Post #406098 Fri Dec 13 2013 11:10pm
RRS Daz
Well that's good news then as I can follow that guide Thumbs Up
It just looks really tight getting to the bolts.
Post #406101 Fri Dec 13 2013 11:23pm
jochem00
Well, it is super easy.
one helpful tip, take both rear wheels off before you start and you can easy see and reach the rear ARC bushes.
Post #406312 Mon Dec 16 2013 7:29am
RRS Daz
Super easy Rolling with laughter
I didn't try to get them off as the parts were wrong but they just looked super difficult.....
I had the wheels off etc as I swapped the link bars, one had play too!!
Post #406320 Mon Dec 16 2013 9:12am
RRS Daz
Just thought I'd update the thread for future readers.
It took I'd say 40 mins to replace both anti roll bar bushes, it's currently 2 deg and working on a driveway...
To be fair there was two of use tackling it.
One school boy error I did was use the ratchet socket too long then I couldn't get it off, so out come the hammer. Best tool was ratchet spanner then the swan neck.
Post #410471 Tue Jan 21 2014 1:33pm
Paul Holywood
if and when mine need replacing, fancy doing mine Daz?? Thumbs Up
Post #410534 Tue Jan 21 2014 8:20pm
RRS Daz
Long trip up to Yorkshire old boy Thumbs Up
I'd advise people not to shy away from doing them if you can twirl a spanner!!
Also cleaned surface rust off break pipes and treated.
So id say I've saved over £500 today....
Post #410555 Tue Jan 21 2014 9:43pm
Paul Holywood
Only joking fella Thumbs Up
Nice darts btw, 500 sovs is a nice saving in anyone's wallet. Wink
Post #410558 Tue Jan 21 2014 9:47pm
RRS Daz
Darts??
Post #410562 Tue Jan 21 2014 10:01pm
