Home > Technical > Rumbling noise
Jonesyscoob
Rumbling noise
Has started to get a bit louder recently, thought it was a wheel bearing, jacked it up and there is a noise when spinning either rear wheel, this noise only comes on when lift of the accelerator and I'm positive it's from the rear, it goes away a little if I drop into neutral but doesn't disappear, could it be the diff, mileage is 90k, any help or advice welcome
Post #403485 Sun Nov 24 2013 9:42pm
I think RRSTDV8 had i similiar noise from the rear diff, he had his replaced. I'm sure he will be along soon to give his imput.
Post #403487 Sun Nov 24 2013 9:52pm
Jonesyscoob
Thanks also got a bit of clonk when I brake sometimes, just done all arb bushes which has solved most of my noises but still this one?
Post #403493 Sun Nov 24 2013 10:03pm
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
I had similar noise plus vibrating through the steering wheel turned out to be the front diff. Big Cry
It was only really noticeable after 30mph on wards when lifting off the accelerator. Did exactly what you did jacked it up and spun the wheel the whirring noise was still there coming from the diff.
Post #403531 Mon Nov 25 2013 12:38am
Jonesyscoob
What's the best way to determine if its front or rear diff then?
Post #403537 Mon Nov 25 2013 7:40am
Disco_Mikey
Chassisear kit, or drain the diffs, and check the condition of the oil.
Should be pretty apparent which diff is faulty, by condition/colour of the oil Thumbs Up
Post #403539 Mon Nov 25 2013 8:08am
Not sure I can add much. Mine was dealt with by the dealer under warranty. 2012 SDV6 - it's missing a couple of cylinders
Post #403630 Mon Nov 25 2013 9:56pm
