![]() | Home > Technical > Rumbling noise |
I think RRSTDV8 had i similiar noise from the rear diff, he had his replaced. I'm sure he will be along soon to give his imput. |
| Jonesyscoob Member Since: 21 Oct 2012 Location: Birmingham Posts: 95
Thanks also got a bit of clonk when I brake sometimes, just done all arb bushes which has solved most of my noises but still this one? |
| Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104
I had similar noise plus vibrating through the steering wheel turned out to be the front diff. |
What's the best way to determine if its front or rear diff then? |
Chassisear kit, or drain the diffs, and check the condition of the oil.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
Not sure I can add much. Mine was dealt with by the dealer under warranty. 2012 SDV6 - it's missing a couple of cylinders
| All times are GMT |
