Home > Maintenance & Modifications > [HELP] RRS Sport 2.7 Tuning Box Installation
Page 1 of 4 1234>
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
So I bought a tuning box of eBay from a seller who's sold 50+ and has 100% feedback, customer's also wrote that it worked perfect lalala.
But, I am trying to install the box into my 2008 TDV6 2.7 with the sellers instructions but nothing matches up, the connections look different.
Can anybody help me find the common rail sensor where this box is supposed to connect into ( A 3-Pin connector, all I can see are 2 pin connectors )
Here are some pictures,
Post #400681 Thu Oct 31 2013 4:52pm
Dhups
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Hi Karan538
Can't tell you where its fits but I was considering getting one too.
Who did you buy this from on eBay? and how much was it as the price ranges so much I just wasn't sure what to go for.
Thanks
Post #400686 Thu Oct 31 2013 5:27pm
karan538
http://www.ebay.co.uk/itm/DIESEL-TUNING-PE...5d26e3bc9b
Delivery was quick, very helpful guy, great seller.
But I still cant find the connector Sad
Post #400691 Thu Oct 31 2013 6:46pm
Dhups
give the guy a call and ask...hopefully he will know. Thumbs Up
Post #400723 Thu Oct 31 2013 10:14pm
Disco_Mikey
On an 08MY, it is on the passenger side (UK car Thumbs Up ) of the engine, on the end of the fuel rail that runs just in front of the injectors.
You can just make it out in the first picture, bottom right hand corner, just behind the white peg for the engine cover. The silver pipe runs over the middle of it in the picture Thumbs Up
Post #400746 Fri Nov 01 2013 7:53am
adigorn
you can see you sensor on picture 1 and 3
the end of black tube feeding injectors (the common rail) Wink
Post #400747 Fri Nov 01 2013 7:54am
sparky8181
Ive looked at these in the past for other vehicles & always decided against it, from what ive read they can cause problems and that you are always better off going for a proper remap.
I would be interested to see how you get on though, keep us informed Thumbs Up
Post #400753 Fri Nov 01 2013 9:14am
karan538
Found the sensor thanks guys it is a 3 pin connector and is also clear in the instructions, going to install it now will keep you guys informed on performance/fuel consumption
Very Happy
Post #400797 Fri Nov 01 2013 2:22pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Can't wait to see if this works! Its a good prize for about 228 horses on a sport tdv6 2.7 RRS 2006 2.7 HSE
Post #400815 Fri Nov 01 2013 5:39pm
Dhups
Yes - interested to see too.
There are various options on ebay. But if you then go top their websites the mention that there are different types of chips that have different upgrades levels... so I was never sure Neutral
Post #400818 Fri Nov 01 2013 5:53pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Be very very careful that it is not the type which simply confuses the ECU by over fuelling to get extra bhp
My wife had a well known tuning chip fitted to her Citroen C Crosser (same engine as the Freelander) and any heavy use of the throttle resulted in the car constantly going into limp mode, needing a short stop to allow the ECU to reset
I would only ever go the remap route in future
Post #400824 Fri Nov 01 2013 6:59pm
karan538
Hi guys,
So after installing I have had a 20min drive to work, I can say that it has made quite a bit off a difference.
Turbo lag as stated has been reduced when foot is down, car feels much more responsive and can feel the pickup in acceleration.
Before installation I was averaging around 20mpg, now with the box its gone slightly upto 22mpg. That is good considering I have the dip switches set up high to performance and may result in higher mpg if you have the box tuned down.
Overall, I think its well worth the £75, you cant go wrong! Thumbs Up
Also I advise if your buying of eBay check the feedback of the product and make sure the box is just not a 'resistor' box or generic as I have seen online, Make sure it is a micro-chip digital based box which is only for the Land Rover as there more specific to your engine
Post #400825 Fri Nov 01 2013 7:06pm
RRSNorway
How can you see if this is a safe box or not? RRS 2006 2.7 HSE
Post #400832 Fri Nov 01 2013 7:34pm
Paulcp
TBH I can't help you there. The one I mentioned was of a similar design from a well known company selling for more than double the one purchased by the OP. It also was only set on 3 of the possible 6 switches.
After thinking about the problems which my wife had I concluded (maybe incorrectly!) that any device which merely connects to the electronics of the injectors can only work by either increasing fuel flow or pressure. In some cases there may be sufficient tolerance built in to cope with this but without the ECU being adjusted to monitor turbo boost and air flow it just seems to me that something is not quite right.
I know that plenty of people use them without issues but for me, if you want more power, the only way to is to do it properly and get a remap. I certainly would not put a tuning box on a car which is still within the warranty period.
Post #400833 Fri Nov 01 2013 7:59pm
Dhups
karan538 wrote:
Hi guys,
Sounds good will give it a try. Thumbs Up
Just ordered mine should be here by next tueday... will let you know how i get on. Smile
Post #400838 Fri Nov 01 2013 8:42pm
Page 1 of 4 1234>
