![]() | Home > Maintenance & Modifications > [HELP] RRS Sport 2.7 Tuning Box Installation |
Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183 ![]() ![]() ![]() |
Hi Karan538
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 ![]() ![]() |
http://www.ebay.co.uk/itm/DIESEL-TUNING-PE...5d26e3bc9b
give the guy a call and ask...hopefully he will know. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
On an 08MY, it is on the passenger side (UK car |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
you can see you sensor on picture 1 and 3
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
Ive looked at these in the past for other vehicles & always decided against it, from what ive read they can cause problems and that you are always better off going for a proper remap.
Found the sensor thanks guys it is a 3 pin connector and is also clear in the instructions, going to install it now will keep you guys informed on performance/fuel consumption
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
Can't wait to see if this works! Its a good prize for about 228 horses on a sport tdv6 2.7 RRS 2006 2.7 HSE |
Yes - interested to see too.
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
Be very very careful that it is not the type which simply confuses the ECU by over fuelling to get extra bhp My wife had a well known tuning chip fitted to her Citroen C Crosser (same engine as the Freelander) and any heavy use of the throttle resulted in the car constantly going into limp mode, needing a short stop to allow the ECU to reset I would only ever go the remap route in future |
Hi guys,
How can you see if this is a safe box or not? RRS 2006 2.7 HSE |
TBH I can't help you there. The one I mentioned was of a similar design from a well known company selling for more than double the one purchased by the OP. It also was only set on 3 of the possible 6 switches.
Sounds good will give it a try. ![]() Just ordered mine should be here by next tueday... will let you know how i get on. ![]() |
