![]() | Home > General > Dodgy Cruise Control |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Could be the brake pedal switch. The switch has two actions - the first slight press of the pedal disables the cruise control, a further press then activates the brake lights. Be worth checking the switch. Others on here have said it's a cheap fix and possible to do at home. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
Generally, either a switch pack or wiring in behind the airbag |
There are a few posts on the Disco3 site about similar problems associated with something called the 'clock spring' which is inside the steering wheel and is (unfortunately) around £300 IIRC. Think it makes the electrical contact from the wheel to the car.
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 ![]() ![]() ![]() |
Thanks all for the replies..
Answers have already been given |
Brake light switch swop never a bad idea as they have a limited life. Order one from site sponsor Duckworth parts and mention the forum to get 10% discount. Cheaper than eBay |
That's a great little how-to Paddi |
Bodsy cheers pal and paddi thanks for the write up that is awesome. I have ordered loads from Dan in the past so will email him now for the switch and then see what happens after I follow your guide.
While replacing the switch is always a good idea, due to them being a |
Ahh man then it sounds then it could be the wiring like your D3... Can you advise what you had to do to fix it? Cheers DM ![]() |
The wiring loom in behind the airbag... ![]() |
DM.. what I meant to say was was the loom replaced or was it just cracked or something? cheers |
The loom was replaced. Visually, it all looked fine, but obviously a hidden issue someplace. Was not expensive either. £12 inc VAT |
DM, have got the part number for this.? cheers |
