Home > General > Dodgy Cruise Control
saty
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Hi all,
I have always had issues with the cruise control on my car since I bought it 2 years back where it works sometimes and then decides not to work. So when I press the + button on the steering wheel nothing happens. If I pull over and turn the car off and on again it sometimes start to work again.
Now it does not work at all !! Nothing when I press the buttons.
Any ideas ?
(Ps car is a 2005 2.7 HSE)
Post #392999 Wed Aug 28 2013 11:12am
Could be the brake pedal switch. The switch has two actions - the first slight press of the pedal disables the cruise control, a further press then activates the brake lights. Be worth checking the switch. Others on here have said it's a cheap fix and possible to do at home. 2012 SDV6 - it's missing a couple of cylinders
Post #393008 Wed Aug 28 2013 1:05pm
Disco_Mikey
Generally, either a switch pack or wiring in behind the airbag Thumbs Up
Even though the wiring looks ok, it can still cause problems
Post #393021 Wed Aug 28 2013 3:11pm
Paddi
There are a few posts on the Disco3 site about similar problems associated with something called the 'clock spring' which is inside the steering wheel and is (unfortunately) around £300 IIRC. Think it makes the electrical contact from the wheel to the car.
Bodsy knows all about it and will be along shortly no doubt Thumbs Up
Brake switch is about £14 from LR, can be fitted in no time and has another less well known function - it shuts off the fuel under braking.
So another symptom of brake light switch failure can be worsened fuel economy. Shocked 2008 MY Java Black TDV8 HSE
Post #393027 Wed Aug 28 2013 4:17pm
saty
Thanks all for the replies..
First thoughts are that the brake switch seems ok as not having any other issues.. But you never know I suppose and for £15 odd quid I might as well replace it.
I hope it is not the £300 spring from the steering wheel Shocked
Waiting for Bodsy to come along Cool
Post #393030 Wed Aug 28 2013 5:00pm
Bodsy
Site Sponsor
Answers have already been given Thumbs Up
Brake pedal switch (try diving with foot under the brake pedal to ensure it is completely at the top)
Wiring behind the airbag
Clock spring (or rotary coupler by its proper name)
Process of elimination, the first two are cheap and straight forward to do, the third makes you cry when you have to pay Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #393046 Wed Aug 28 2013 7:47pm
Paddi
Brake light switch swop never a bad idea as they have a limited life. Order one from site sponsor Duckworth parts and mention the forum to get 10% discount. Cheaper than eBay Shocked
Here is link to my poor attempt at a 'how to': http://rrsport.co.uk/forum/topic30757.html...dal+switch 2008 MY Java Black TDV8 HSE
Post #393050 Wed Aug 28 2013 8:36pm
That's a great little how-to Paddi Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #393052 Wed Aug 28 2013 8:44pm
saty
Bodsy cheers pal and paddi thanks for the write up that is awesome. I have ordered loads from Dan in the past so will email him now for the switch and then see what happens after I follow your guide.
Cheers again all Thumbs Up Thumbs Up
Post #393164 Thu Aug 29 2013 4:30pm
Disco_Mikey
While replacing the switch is always a good idea, due to them being a Censored design, if you had a faulty pedal switch, you would have more issues than just the CC not working properly Thumbs Up
My D3 had EXACTLY the same issue as yours does, and was the wiring in behind the airbag Thumbs Up
Post #393267 Fri Aug 30 2013 6:44am
saty
Ahh man then it sounds then it could be the wiring like your D3... Can you advise what you had to do to fix it?
Cheers DM Thumbs Up
Post #393308 Fri Aug 30 2013 10:46am
Disco_Mikey
Cheers DM Thumbs Up
The wiring loom in behind the airbag... Confused
Post #393350 Fri Aug 30 2013 3:10pm
saty
DM.. what I meant to say was was the loom replaced or was it just cracked or something? cheers
Post #393352 Fri Aug 30 2013 3:25pm
Disco_Mikey
The loom was replaced. Visually, it all looked fine, but obviously a hidden issue someplace. Was not expensive either. £12 inc VAT Thumbs Up
Post #393383 Fri Aug 30 2013 9:46pm
saty
DM, have got the part number for this.? cheers
Post #393579 Mon Sep 02 2013 4:59pm
