![]() | Home > Maintenance & Modifications > 2.7 Range Rover Sport EGR Valves out & ECU Tuning Remap |
Mixy Member Since: 20 Feb 2012 Location: Cheadle Posts: 39 ![]() ![]() ![]() |
Loads of stuff on here already but just thought I would say that I have removed my EGR Valves and had my ECU remapped and the car is miles better, MPG better and performance is up, worth the few hundred quid!
Preston-rr Member Since: 10 Sep 2010 Location: Preston Posts: 239 ![]() ![]() ![]() |
Being very new what do the EGR valves do? Why are they there if they are not needed?
take it there is no issue with getting through an MOT with them not operational? Just found out that Flack is 2 mins from me so have reqeusted his prices for all things RRS including EGR work. 2014 RRS HSE, SVR body kit fitted.
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
What's dpf? How much was the remap? I'm in lpool so may book a slot. Also blanked the EGRS YESTERDAY and oh what a difference. Mpg up from 19 to 26 |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Diesel Particulate Filter Since mine is a 2007, I can't blank the EGR's. ![]() ![]() 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone ![]() 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
Alonso92 Member Since: 22 Oct 2016 Location: London Posts: 13 ![]() ![]() ![]() |
//thread back to life//
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5053 ![]() ![]() ![]() |
you can but you need to reprogram the ecu to prevent the light coming on |
Cheers Andy. Who can do that and how much do they normally charge? Looking at blanking them off to avoid future problems and getting a remap put on by AMD. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4475 ![]() ![]() ![]() |
Speak to Alive Tuning. They can put you in touch with their nearest dealer, who can blank the EGRs, and provide you with a top notch remap |
Just had a look at them but theyre a bit far from london and would rather do the blanking myself to save a couple of quid 👍🏻 |
They have dealers all over the country |
Great ill give them a call a bit later |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
Blanked off my EGRs this morning. A bit fiddly but fairly straightforward, took about 2 hours. Car started first time, ran fine, no smoke and no EML on dash. The write up on the Disco3 forum was very helpful.
Thanks for the link phil, mucho appreciated will give it a crack next weekend. To save me starting a new thread, does a 2008 2.7 sport have a dpf or did they come on later models? |
