Home > Technical > Vibration during acceleration, slipping clutch? (TDV6)
mathino
Finland 2006 Range Rover Sport TDV6 SE Baltic Blue
I have a 2006 RRS with the TDV6 engine. I have noticed a vibration during acceleration, most obvious it seems to be in third gear. It feels like something is either not fully balanced or like a slipping clutch. It stops if I lift the gas pedal a little or when the gearbox changes to the next gear.
I am not quite familiar to the mechanics of the automatic gearbox, is there a clutch that can be slipping? Or can it be the torque converter? The vibration has slowly become worse during the last 10k miles.
Any ideas?
Post #383035 Tue May 14 2013 2:33pm
Maybe failing tc
Have you tried a stall test? RRS gone
Post #383687 Tue May 21 2013 4:19pm
mathino
Thanks for your reply. What is a stall test?
Post #383710 Tue May 21 2013 8:21pm
Engine running, left foot firmly on brake pedal. Put in drive, bring in the throttle with the right foot. Revs will increase (and the rear will squat slightly). At about 2.2k-2.5k rpm the revs will stop rising. If the revs keep rising then the TC might be tired.
Don't do this for more than a few seconds (as the gearbox will get hot quickly) and make sure you keep the brakes on until the revs are back at idle. 2012 SDV6 - it's missing a couple of cylinders
Post #383778 Wed May 22 2013 1:34pm
super-si
Vibration
Where do you feel the vibration? how severe is it?
Post #383837 Wed May 22 2013 8:51pm
Bodsy
Site Sponsor
Probably happens in third gear, when revs are about 1500-2000. You'll probably notice the revs will fluctuate in line with the vibration.
Failing torque converter I'm afraid.
You can try changing the oil with a Megaflush or using some Dr Tranny, but end result is likely to be the same. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #383851 Wed May 22 2013 11:02pm
chuckmiester
2006 Range Rover Sport TDV6 HSE Java Black
i don't want to steal someone else's thread but mine has been doing this for about 12 months and not really got any worse. How long does the tc normally last when the vibration starts?
Post #384245 Wed May 29 2013 9:56am
m2sa
Estonia 2007 Range Rover Sport TDV6 Autobiography Orkney Grey
Hey
I have exacly the same problem on my RRS 2,7 2007 like mathino.
i have changed the gearbox oil, front diff oil. Drive shaft bearings, but its still there.
Have anyone find solution for this problem?
Thanks
Mikk
Post #437590 Wed Sep 24 2014 11:14am
