![]() | Home > Technical > Vibration during acceleration, slipping clutch? (TDV6) |
Maybe failing tc
mathino Member Since: 14 May 2013 Location: Vaasa Posts: 2 ![]() ![]() ![]() |
Thanks for your reply. What is a stall test? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
Engine running, left foot firmly on brake pedal. Put in drive, bring in the throttle with the right foot. Revs will increase (and the rear will squat slightly). At about 2.2k-2.5k rpm the revs will stop rising. If the revs keep rising then the TC might be tired.
super-si Member Since: 09 Feb 2012 Location: West Yorkshire Posts: 43 ![]() ![]() |
Where do you feel the vibration? how severe is it? |
Probably happens in third gear, when revs are about 1500-2000. You'll probably notice the revs will fluctuate in line with the vibration.
chuckmiester Member Since: 01 Jan 2013 Location: barnsley Posts: 8 ![]() ![]() |
i don't want to steal someone else's thread but mine has been doing this for about 12 months and not really got any worse. How long does the tc normally last when the vibration starts? |
m2sa Member Since: 10 Sep 2014 Location: Tapa Posts: 4 ![]() ![]() ![]() |
Hey
