![]() | Home > Technical > S/C amber engine management light - no fault code |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
If the light is on, there should be a code logged...
Whizzee111s Member Since: 17 Sep 2011 Location: Basildon Posts: 53 ![]() ![]() ![]() |
Had the same issue a month or so back driving to work got the RAC out who checked it and he cleared the fault which he said was a sensor value reading being different between the sensors on the exhaust so the car was running lean. He cleared it and touch wood not had problem again Freelander SE - Gone
Mckelvr Member Since: 08 Dec 2012 Location: Ayrshire Posts: 47 ![]() ![]() ![]() |
Last time mine came on it was the cat |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
mines just come on, its the O2 sensors before cat - £100, job done |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
As D-M said if the light is on there should be a fault code. I've had the light on 3 times recently. First time required a new O2 sensor. Second time it was related to the purge valve, this came on after filling the tank and being stuck in traffic. After a bit of open driving cleared the code using my IDDTool and it never came back. And just now the light was on with a warning "Bank 1 running lean" after a 300km blast at around 120kph the light extinguished itself...
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 ![]() ![]() ![]() |
My light was caused by code P0430. The dealer replaced an O2 sensor and the left-side cat.
