Home > Technical > S/C amber engine management light - no fault code
V88ABA
2007 Range Rover Sport Supercharged Java Black
Tried 5-7 re starts but still showing
Anyone else had this problem. Search only comes up with EGRs however doesn't apply to me.
Any ideas guys?
Post #381508 Fri Apr 26 2013 11:45am
Disco_Mikey
If the light is on, there should be a code logged...
Probably a Lambda sensor
Post #381517 Fri Apr 26 2013 12:47pm
Whizzee111s
England 2010 Range Rover Sport Supercharged Santorini Black
Had the same issue a month or so back driving to work got the RAC out who checked it and he cleared the fault which he said was a sensor value reading being different between the sensors on the exhaust so the car was running lean. He cleared it and touch wood not had problem again Freelander SE - Gone
S1 Elise - weekender
Rrsport S/C Autobiography 10 plate -well and truely here, but now stolen
Post #381557 Fri Apr 26 2013 10:19pm
Mckelvr
United Kingdom 2009 Range Rover Sport 4.4 V8 Stornoway Grey
Last time mine came on it was the cat
Post #381651 Sun Apr 28 2013 3:13pm
B3EEE
Wales 2005 Range Rover Sport Supercharged Vesuvius Orange
mines just come on, its the O2 sensors before cat - £100, job done  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Prefer RR Vouge S/C but they don't do Orange !
Post #381671 Sun Apr 28 2013 8:15pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
As D-M said if the light is on there should be a fault code. I've had the light on 3 times recently. First time required a new O2 sensor. Second time it was related to the purge valve, this came on after filling the tank and being stuck in traffic. After a bit of open driving cleared the code using my IDDTool and it never came back. And just now the light was on with a warning "Bank 1 running lean" after a 300km blast at around 120kph the light extinguished itself...
The above isn't much help though if you're not getting a gault code for the engine...
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #381700 Mon Apr 29 2013 6:24am
USAFBuckeye
United States 2007 Range Rover Sport Supercharged Stornoway Grey
My light was caused by code P0430. The dealer replaced an O2 sensor and the left-side cat.
Good luck! '12 RRS SC
'07 RRS SC
'11 Honda Odyssey Touring Elite (sigh...)
Gone, but not forgotten
'02 RR
'05 LR3 SE7 (Best off-road rig I've ever had) let her go @ 100K miles
Post #381789 Tue Apr 30 2013 6:31am
