![]() | Home > Technical > Power loss |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154 ![]() ![]() ![]() |
Battery sounds a bit tired. Do you have a charger? Might be worth putting it on and getting the battery up to full charge and then see if it drops overnight again. Also, see if the battery is maintained at that level or starts to drop over a couple of days of use. Might be a tired battery or it might be the first signs of an alternator getting tired. If you start the engine and then have someone turn on the lights and heated seats whilst you watch the voltage what does it do? Again, the alternator ought to be able to pick that up without a big drop in voltage on the battery.
11.5 volts with engine off is way too low and suggests battery has had it. Before you splash out £239 for a LR replacement try taking battery off the car and giving it a full charge. Wait two hours and check voltage. Then leave overnight and check it again. Should be above 12.5 volts and not lose more than 0.1 volts overnight. If it is OK then check the battery drain when connected to the car and car is asleep. Think rule of thumb is drain should not be much more than about 20mA. 2008 MY Java Black TDV8 HSE
