![]() | Home > General > My 2007 tdv8 limp mode now won't start |
Sorry i can't help but i'd advise joining a breakdown recovery firm AA, RAC, Green flag etc, Bodsy will be along pretty soon i'm sure he will be able to give you a few ideas to check over first. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9099 ![]() ![]() ![]() |
Battery / alternator failure perhaps? 2012 SDV6 - it's missing a couple of cylinders
Jamma88 Member Since: 23 Dec 2012 Location: Middlesbrough Posts: 24 ![]() ![]() ![]() |
It's bin in and out of garage think its a fuel problem but never seems to get fixed recent new alternator so don't think it's tht |
panpicker Member Since: 27 Dec 2009 Location: buckingham Posts: 38 ![]() ![]() ![]() |
I had the same thing after having my turbos replaced turned out to be the Actuators sticking. mine was a cheap fix. ?? i was told a common problem on TDV8 's |
I hope so I will suggest it to garage only fault code it's bringing up is diesel pressure just hoping its not the pump |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
Fuel filters are guilty for causing all sorts of issues, and an easy and cheap place to start |
I had this after a turbo was replaced. It turned out to be the battery box not refitted correctly and the ecu for gearbox which is under battery, filling with water. It was put right by the dealer who fitted the turbo.
