Home > General > My 2007 tdv8 limp mode now won't start
Jamma88
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Right my car is driving me crazy 2 new turbos last month now this I floor it and the. After a bit car feels like its holding bk then faults cum up suspension fault transmission fault traction control sign then goes into gear (F) and can not change manually I stop car and start again and is fine then same again when foot down just gone out side n car struggled to start the. Did and cut out 2 seconds later now won't start can anyone help me????
Post #374025 Tue Feb 19 2013 9:24pm
Sorry i can't help but i'd advise joining a breakdown recovery firm AA, RAC, Green flag etc, Bodsy will be along pretty soon i'm sure he will be able to give you a few ideas to check over first.
Post #374027 Tue Feb 19 2013 9:30pm
Battery / alternator failure perhaps? 2012 SDV6 - it's missing a couple of cylinders
Post #374028 Tue Feb 19 2013 9:31pm
Jamma88
It's bin in and out of garage think its a fuel problem but never seems to get fixed recent new alternator so don't think it's tht Sad
Post #374031 Tue Feb 19 2013 9:39pm
panpicker
England 2007 Range Rover Sport TDV8 HSE Java Black
I had the same thing after having my turbos replaced turned out to be the Actuators sticking. mine was a cheap fix. ?? i was told a common problem on TDV8 's
Post #374032 Tue Feb 19 2013 9:41pm
Jamma88
I hope so I will suggest it to garage only fault code it's bringing up is diesel pressure just hoping its not the pump
Post #374034 Tue Feb 19 2013 9:45pm
Disco_Mikey
Fuel filters are guilty for causing all sorts of issues, and an easy and cheap place to start Thumbs Up
Post #374071 Wed Feb 20 2013 7:57am
simple1
I had this after a turbo was replaced. It turned out to be the battery box not refitted correctly and the ecu for gearbox which is under battery, filling with water. It was put right by the dealer who fitted the turbo.
Try the filter first which seems like a possible then check fuel lines for kinks then the battery box. The canbus system is a strange animal and can pass faults around the system 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #374089 Wed Feb 20 2013 10:17am
