Home > General > Suspension fault
Sunnyv
2005 Range Rover Sport TDV6 HSE Buckingham Blue
Suspension fault
Can anyone help? I have a 2005 sport HSE, had a problem with the suspension fault "suspension fault normal height only" and the orange wobbly RR indicator. The battery then went flat, charged it and the whole thing died a few minutes later. Took it to a mechanic who changed the battery control system, new alternator and a heating relay at a substantial cost.
The suspension is still playing up and I've been told the suspension control system is showing up faulty.
I'd appreciate any advise I can get as in feel I'm being ripped off.
PEASE HELP!! Sad
Post #373909 Mon Feb 18 2013 9:23pm
PEACHY
You may be unlucky and have 2 different problems occurring at the same time - what do you mean by suspension playing up? Confused 16MY Estoril Blue SVR.............
Post #373912 Mon Feb 18 2013 9:54pm
Sunnyv
Thanks peachy for responding so quick. Poor to having the battery problems sorted I used to get "special programmes off" and "normal suspension hight only" with the orange wobbly indicator. She suspension would lower but then raise to normal hight immediately. just wondering where I go from here, been advised I need a new suspension control unit.
Post #373913 Mon Feb 18 2013 10:01pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
Re: Suspension fault
PEASE HELP!! Sad
Had exactly the same with mine. New air suspension compressor sorted it good as new Thumbs Up Carl
Post #373914 Mon Feb 18 2013 10:04pm
Sunnyv
Thanks Carl will get it checked out. Can the unit be reconditioned?
Post #373915 Mon Feb 18 2013 10:09pm
PEACHY
I can only advise from my own experiences - the suspension Compressor is located in front of the n/s rear wheel - it becomes noisy when its due to fail - mine had been refurbed ( in a fashion ) & started to play up almost straight away after I had purchased the car. It was showing the same faults as yours - it was replaced & it's been great since. The lads on here are great - some are close to genius when it comes to solving problems Whistle Whistle so stick with it !! 16MY Estoril Blue SVR.............
Post #373916 Mon Feb 18 2013 10:13pm
V8SC
....not sure if it can be reconditioned or not but in any event you might find a new one more cost effective anyway. There is a relay that needs to be replaced as well.
This link to the Service Bulletin that applied to a fault might be useful to you ...
http://www.disco3.co.uk/gallery/albums/use...5B1%5D.pdf
Good luck getting it sorted Thumbs Up Carl
Post #373918 Mon Feb 18 2013 10:18pm
Sunnyv
Thanks Cartland peachy for your advice, greatly appreciated. I'll let you know what happens.
Teach me to buy extravagant present for the wife!! Thumbs Up Neutral
Post #373920 Mon Feb 18 2013 10:24pm
PEACHY
That's what everybody says Rolling with laughter Rolling with laughter 16MY Estoril Blue SVR.............
Post #373922 Mon Feb 18 2013 10:25pm
Sunnyv
Hello all, it's me again. I am about to buy a new air suspension control module and wanted to know how and where I would get the right part number. It's a 2005 2.7tdi has, BMW engine.
Post #374191 Thu Feb 21 2013 7:33am
Gary
Sunnyv, definately not BMW Engine, designed by Ford/Peugeot with help from JLR built by Ford at Dagenham
Post #374192 Thu Feb 21 2013 8:25am
It's the Lion V6. Ford / PSA as mentioned.
http://en.wikipedia.org/wiki/Ford_AJD-V6/PSA_DT17 2012 SDV6 - it's missing a couple of cylinders
Post #374201 Thu Feb 21 2013 10:52am
RRS-Spy
Does anyone know if the compressor is covered by the LR warranty ? Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone)
Post #374248 Thu Feb 21 2013 5:43pm
