![]() | Home > General > Suspension fault |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
You may be unlucky and have 2 different problems occurring at the same time - what do you mean by suspension playing up? |
Sunnyv Member Since: 18 Feb 2013 Location: Ilford Essex Posts: 10 ![]() ![]() |
Thanks peachy for responding so quick. Poor to having the battery problems sorted I used to get "special programmes off" and "normal suspension hight only" with the orange wobbly indicator. She suspension would lower but then raise to normal hight immediately. just wondering where I go from here, been advised I need a new suspension control unit. |
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 ![]() ![]() |
Had exactly the same with mine. New air suspension compressor sorted it good as new ![]() |
Thanks Carl will get it checked out. Can the unit be reconditioned? |
I can only advise from my own experiences - the suspension Compressor is located in front of the n/s rear wheel - it becomes noisy when its due to fail - mine had been refurbed ( in a fashion ) & started to play up almost straight away after I had purchased the car. It was showing the same faults as yours - it was replaced & it's been great since. The lads on here are great - some are close to genius when it comes to solving problems |
....not sure if it can be reconditioned or not but in any event you might find a new one more cost effective anyway. There is a relay that needs to be replaced as well.
Thanks Cartland peachy for your advice, greatly appreciated. I'll let you know what happens.
That's what everybody says |
Hello all, it's me again. I am about to buy a new air suspension control module and wanted to know how and where I would get the right part number. It's a 2005 2.7tdi has, BMW engine. |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 ![]() ![]() ![]() |
Sunnyv, definately not BMW Engine, designed by Ford/Peugeot with help from JLR built by Ford at Dagenham |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154 ![]() ![]() ![]() |
It's the Lion V6. Ford / PSA as mentioned.
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 ![]() ![]() ![]() |
Does anyone know if the compressor is covered by the LR warranty ? Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone) |
