![]() | Home > Technical > slight rev counter up/down when starting cold |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Hi RRSCS, I've had the uneven idle running problem on my D3 TDV6 since it was new ( 7 yrs old now),and I remember trying another new one at the dealership way back then,and that did the same |
RRSCS Member Since: 07 Mar 2012 Location: Budapest Posts: 19 ![]() ![]() ![]() |
Dear Texstar,
Yes, let us know how you get on, (the oil temp sensor was just under £30 here in UK). |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Normally have these issues after having the battery disconnected. First cambelt I replaced, I thought the timing was out, causing it to run a bit odd with the fluctuating engine revs. IT eventually sorted itself out though.
Thank you. I will try that too |
Hi Folks,
joeand Member Since: 22 Aug 2012 Location: manchester Posts: 104 ![]() ![]() ![]() |
i had the rev counter up and down a few months back had the maf cleaned out and was perfect after that, i have a range rover 4.2 supercharge |
Hi there, I got the MAF changed as well, still does it though |
