Home > In Car Electronics > How do i play video from USB on rear screens? |
kryten22uk Member Since: 01 Dec 2012 Location: Croydon Posts: 36 |
I also tried avi/DivX and WMV formats but none worked. So is the USB option under "My Video" simply a red herring? |
Sat Dec 08 2012 12:32pm |
It tells you the formats etc in the manual Mike
Sat Dec 08 2012 10:27pm |
It doesn't! I've read through and it goes into detail for Audio but not for Video. If you are able to post the page number I can see if I have been a doofus and missed it. Ta. I think the issue might be that USB for video is only for connecting video players and hence maybe it's only meant to receive video streaming and not supposed to read a file for which it has to decode and play (like it does if the USB stick had mp3's on). |
Sun Dec 09 2012 11:34am |
Pg117 I think Mike
Sun Dec 09 2012 12:10pm |
Pg125 also covers it. I only tried it once and it worked straight away from a vod file Mike
Sun Dec 09 2012 12:13pm |
Thanks for the reply. We seem to have different handbook versions. Did it change for 2012 cars? My pg117 is on Radio and pg125 is on Portable Music Players. Maybe the details on formats was "enhanced" out in my version?
Sun Dec 09 2012 12:46pm |
Yes it's from the latest version for the 2013my car.
Sun Dec 09 2012 2:36pm |
Downloaded the latest manual from Topix and it's the same information as mine, just in different page numbers. Basically there's nothing that lists video file compatibility, only audio files. I'll have to contact landrover to enquire whether possible and if so what format/how. |
Sun Dec 09 2012 2:55pm |
Ill try it again on Tuesday...i used one of the movies i had so it was likely a .WMV - have you tried that on a correctly formatted USB? Mike
Sun Dec 09 2012 10:09pm |
Yeah, it says format FAT or FAT32, so I did that and added an WMV file, but no cigar. |
Sun Dec 09 2012 11:05pm |
mattwood Member Since: 25 Feb 2012 Location: Littleborough Posts: 2 |
Hi
Sun Dec 16 2012 6:51pm |
It was in avi file format |
Sun Dec 16 2012 7:31pm |
Henrik Member Since: 10 Dec 2013 Location: Luxembourg Posts: 2 |
Hi,
Thu Dec 19 2013 3:41pm |
P.S. I have a MY2014 RRS, so might be a bit different. |
Thu Dec 19 2013 3:46pm |
