Home > In Car Electronics > How do i play video from USB on rear screens?
kryten22uk
Got rear screens on my MY12. I want to load a bunch of movies onto a USB stick and plug it into my RRS so that I can search through and choose a movie to play for the kids, much like you might save a load of mp3 music tracks onto a usb stick.
I put an MP4 video on a usb stick and plugged it didnt recognise any movies. Maybe it doesn't like mp4 so I'm in the process of converting it to DivX to try that.
Has anyone tried or succeeded to watch video via usb?
Post #365095 Sat Dec 01 2012 9:24pm
kryten22uk
I also tried avi/DivX and WMV formats but none worked. So is the USB option under "My Video" simply a red herring?
Post #365850 Sat Dec 08 2012 12:32pm
mse
It tells you the formats etc in the manual Rolling Eyes Mike
2014 Facelift Discovery
Post #365923 Sat Dec 08 2012 10:27pm
kryten22uk
It doesn't!
I've read through and it goes into detail for Audio but not for Video. If you are able to post the page number I can see if I have been a doofus and missed it. Ta.
I think the issue might be that USB for video is only for connecting video players and hence maybe it's only meant to receive video streaming and not supposed to read a file for which it has to decode and play (like it does if the USB stick had mp3's on).
Post #365982 Sun Dec 09 2012 11:34am
mse
Pg117 I think Mike
Post #365990 Sun Dec 09 2012 12:10pm
mse
Pg125 also covers it. I only tried it once and it worked straight away from a vod file Mike
Post #365991 Sun Dec 09 2012 12:13pm
kryten22uk
Thanks for the reply. We seem to have different handbook versions. Did it change for 2012 cars? My pg117 is on Radio and pg125 is on Portable Music Players. Maybe the details on formats was "enhanced" out in my version?
Do you have chapter titles so that I could check that way instead?
Also, you say it worked with a VOD file on your USB. I wasnt aware that .VOD was a video format; isnt it just a method for obtaining streaming media? There is a section in my manual about obtaining VOD from DIVX's streaming media service, but thats a paid-for service, not same as taking own movies on flashdrive.
Post #365995 Sun Dec 09 2012 12:46pm
mse
Yes it's from the latest version for the 2013my car.
Just look on topix I would suggest Mike
Post #366007 Sun Dec 09 2012 2:36pm
kryten22uk
Downloaded the latest manual from Topix and it's the same information as mine, just in different page numbers. Basically there's nothing that lists video file compatibility, only audio files. I'll have to contact landrover to enquire whether possible and if so what format/how.
Post #366008 Sun Dec 09 2012 2:55pm
mse
Ill try it again on Tuesday...i used one of the movies i had so it was likely a .WMV - have you tried that on a correctly formatted USB? Mike
Post #366059 Sun Dec 09 2012 10:09pm
kryten22uk
Yeah, it says format FAT or FAT32, so I did that and added an WMV file, but no cigar.
Post #366065 Sun Dec 09 2012 11:05pm
mattwood
Hi
Took me ages to work this out when I tried.
I had to plug the USB stick in the rear connection and select the files from the stick using the rear controller.
I will check what format the video is in.
Matt
Post #366802 Sun Dec 16 2012 6:51pm
mattwood
It was in avi file format
Post #366808 Sun Dec 16 2012 7:31pm
Henrik
Luxembourg 2013 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Anyone else any success with this? I can get files on a USB stick to play on the front screen, although not all the time, but can't get the same file to play on the rear screen. It can see the file, but after a second or so it comes up with track error. I can't believe they have a different solution or support differenct for front and back. Quite disappointed that I can't play from the front USB to the rear screens too. What were LR thinking of? It works fine from a real DVD, so why not from a USB?
Also, anyone any success from different formats? I've seen somewhere that MP4 is supported, but can't find anyone who actually got it to work.
I'll have a play over the next few days and will post some results.
Post #406709 Thu Dec 19 2013 3:41pm
Henrik
P.S. I have a MY2014 RRS, so might be a bit different.
Post #406710 Thu Dec 19 2013 3:46pm
