Home > General > POLLEN FILTER - location??
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
I've recently been driving in Spain through an area with a very high pollen count. I would like to locate the pollen filter in my 2006 sport and, if it is possible, give it a clean. I would be grateful of any advice! Andrew Andrew Kennedy
Post #355192 Fri Aug 31 2012 12:27pm
Paddi
Behind the glove box. Open it and then push down on the levers either side and the glove box when it will drop down further. Look behind and above the glove box (a torch helps) and you will see a rectangular door which is latched at one end. Remove the door and in the cavity now exposed you will see the pollen filter at the top; just pull it out. Not sure how effective cleaning it will be. Good quality activated charcoal filters can be found (in the UK anyway) for about GBP10. There is a video here which shows you the process of changing the filter if my description is not clear. And no; - that's not me in the video. 2008 MY Java Black TDV8 HSE
Post #355200 Fri Aug 31 2012 1:41pm
Bobby
See my Gallery..
http://www.rrsport.co.uk/gallery/albums/us...ilter2.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #355206 Fri Aug 31 2012 2:43pm
andrew kennedy
Pollen filter
Many thanks Paddi - I'm on the case....Andrew Andrew Kennedy
Post #355207 Fri Aug 31 2012 2:51pm
andrew kennedy
Pollen filter?!?
Paddi - I've taken the filter out...cleaned it...the way the filter came out was showing the 'Air Flow' simble showing the air came in form the top . Could you confirm this is the correct way up for the filter to be. Andrew Andrew Kennedy
Post #355259 Sat Sep 01 2012 10:26am
Paddi
Andrew,
Airflow comes from above (switch the fan on and you'll feel it drawing air downward). On some filters the arrows showing airflow direction are printed on the moveable flange so you can make them point in either direction Laughing
I think the filter should be orientated with the flanges at the bottom to help provide a seal but TBH the filter looks symmetrical so may not be all that important. No doubt someone will be along in a minute with the definitive answer. 2008 MY Java Black TDV8 HSE
Post #355271 Sat Sep 01 2012 12:23pm
andrew kennedy
Pollen filter
Paddi wrote:
Andrew,
Thanks. What you are saying applies to my filter....so I know what to do. Again many thanks!! Andrew Kennedy
Post #355283 Sat Sep 01 2012 2:35pm
