| RRSPORT.CO.UK | ||
|  | Home > General > POLLEN FILTER - location?? |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Behind the glove box. Open it and then push down on the levers either side and the glove box when it will drop down further. Look behind and above the glove box (a torch helps) and you will see a rectangular door which is latched at one end. Remove the door and in the cavity now exposed you will see the pollen filter at the top; just pull it out. Not sure how effective cleaning it will be. Good quality activated charcoal filters can be found (in the UK anyway) for about GBP10.  There is a video here  which shows you the process of changing the filter if my description is not clear. And no; - that's not me in the video. 2008 MY Java Black TDV8 HSE
|  Fri Aug 31 2012 12:41pm |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | See my Gallery..
|  Fri Aug 31 2012 1:43pm |
| andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 348      |
 Many thanks Paddi - I'm on the case....Andrew Andrew Kennedy | ||
|  Fri Aug 31 2012 1:51pm |
 Paddi - I've taken the filter out...cleaned it...the way the filter came out was showing the 'Air Flow' simble showing the air came in form the top . Could you confirm this is the correct way up for the filter to be. Andrew Andrew Kennedy | ||
|  Sat Sep 01 2012 9:26am |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Andrew,
|  Sat Sep 01 2012 11:23am |
 Thanks. What you are saying applies to my filter....so I know what to do. Again many thanks!! Andrew Kennedy | ||
|  Sat Sep 01 2012 1:35pm |
| Posting Rules
