Home > Technical > rrs 2010 brake light
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi can anybody help me with the removal of rear spoiler brake light led removal please cheers
Post #354350 Tue Aug 21 2012 3:39pm
Sorry, i can't help, but maybe X5pea might be able to when he sees this post.
Post #354375 Tue Aug 21 2012 9:05pm
Bobby
You need to remove the rear spoiler in order to gain access to the brake lights. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #354407 Wed Aug 22 2012 12:03am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
yep total pain
Post #354435 Wed Aug 22 2012 3:38pm
merlin1
Cheers will have to sort over the weekend
Post #354541 Thu Aug 23 2012 8:31pm
jpeart
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
I've just noticed that 4 of the LED bulbs are u/s in the cluster of bulbs in the rear spoiler brake light. Is it possible to replace the bulbs individually or do you have to replace the cluster?
Also, any instruction vids / docs anywhere on how to remove spoiler and replace bulbs / cluster?
Thanks
Jon
Post #460987 Sat May 02 2015 2:40pm
ABSport
You have to replace the the whole light. Easy to remove just open top section of boot undo the two bolts holding the spoiler on ( there is 4 in total ) close the boot. Then open the boot completely ( bottom section ) then you will see 2 further bolts each corner holding the spoiler on.
Once removed carefully lift off and use a step ladder as you don't want to mark the paint. Then just undo the rear wash pipe and the electric plug. Once spoiler removed the plastic part (underneath will pull apart exposing the light and then remove the light. Thumbs Up
Post #460991 Sat May 02 2015 3:20pm
Three Nuts, Two Bolts and One Multi-Plug, Two If you have Reverse Camera and Washer Pipe plus Two Small Nuts on Brake Light Unit. Be careful when lift it off as the Studs can Scratch Roof Paintwork easier if you have extra pair of hands when you lift it.
Post #460992 Sat May 02 2015 3:22pm
