![]() | Home > Technical > rrs 2010 brake light |
Sorry, i can't help, but maybe X5pea might be able to when he sees this post. |
You need to remove the rear spoiler in order to gain access to the brake lights. Malaysia Boleh!
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
yep total pain |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 ![]() ![]() |
Cheers will have to sort over the weekend |
jpeart Member Since: 02 May 2015 Location: Leicester Posts: 2 ![]() ![]() ![]() |
I've just noticed that 4 of the LED bulbs are u/s in the cluster of bulbs in the rear spoiler brake light. Is it possible to replace the bulbs individually or do you have to replace the cluster?
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
You have to replace the the whole light. Easy to remove just open top section of boot undo the two bolts holding the spoiler on ( there is 4 in total ) close the boot. Then open the boot completely ( bottom section ) then you will see 2 further bolts each corner holding the spoiler on.
Three Nuts, Two Bolts and One Multi-Plug, Two If you have Reverse Camera and Washer Pipe plus Two Small Nuts on Brake Light Unit. Be careful when lift it off as the Studs can Scratch Roof Paintwork easier if you have extra pair of hands when you lift it.
