Home > In Car Electronics > iPhone connected to AUX - higher sound on the right side |
Carlos3 Member Since: 14 Apr 2013 Location: Chester Posts: 40 |
Has anyone ever worked this out as i have the same problem |
Sun Dec 08 2013 12:37pm |
Not had that problem but you generally get much louder and better quality sound if you connect the 'phone using a dock connector like this;
Sun Dec 08 2013 2:41pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Plus one on the above- sound quality will be far far better and it will charge your iphone/pod too. |
Sun Dec 08 2013 3:03pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1744 |
Why will the sound be better, it is still only using the Aux for audio? 2023 P440e SE Dynamic on order -cancelled
Sun Dec 08 2013 4:21pm |
Well it definitely is on my car. I've tried both dock to jack and jack to jack and there is big difference. Apple designed the dock connector to be lineout for connection to amps and the headphone out for connection to er.. headphones. I think the dock out is not processed by the circuits designed to provide headphone output (for example the volume is not controlled by the iPhone's volume control which is more convenient). No doubt somebody who can explain it in technical terms will be along soon 2008 MY Java Black TDV8 HSE
Sun Dec 08 2013 5:49pm |
I can believe that the volume is higher, so I guess you need less volume on the car and so less distortion?
Sun Dec 08 2013 6:04pm |
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 |
I too have the same cable which works perfectly. worth getting a usb>in car charger aswell for a few quid. |
Mon Dec 09 2013 7:15pm |
