Home > In Car Electronics > iPhone connected to AUX - higher sound on the right side
pontone
Sweden 2007 Range Rover Sport TDV8 HSE Java Black
Hi, I have a RRS TDV8 HSE 2007 in which I have my iPhone 4 connected to the rear AUX input. The cable is a 3.5mm which goes into AUX input and 3,5mm which goes in to the top of the iPhone. From what I have read this is the way to connect the iPhone to the car stereo and get itunes and Spotify out to the car speakers. Question why is it louder sound on the right side speakers (it still delivers sound on the left side though, but not far as loud as on the right side)? and yes, of course I have checked the balance settings in the head unit...
Post #348331 Sun Jun 24 2012 4:31pm
Carlos3
England 2007 Range Rover Sport TDV8 HST Java Black
Has anyone ever worked this out as i have the same problem
Post #405303 Sun Dec 08 2013 12:37pm
Paddi
Not had that problem but you generally get much louder and better quality sound if you connect the 'phone using a dock connector like this;
http://item.mobileweb.ebay.co.uk/viewitem?itemId=271233635439
Cheap enough and may even fix the problem. Thumbs Up
EDIT: JUST NOTICED THE PRICE IN THAT LINK - THESE CAN BE HAD FOR MUCH LESS - ABOUT £2.99 IF YOU SHOP AROUND 2008 MY Java Black TDV8 HSE
Post #405312 Sun Dec 08 2013 2:41pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Plus one on the above- sound quality will be far far better and it will charge your iphone/pod too.
Post #405317 Sun Dec 08 2013 3:03pm
jimbg
Why will the sound be better, it is still only using the Aux for audio? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #405324 Sun Dec 08 2013 4:21pm
Paddi
Well it definitely is on my car. I've tried both dock to jack and jack to jack and there is big difference. Apple designed the dock connector to be lineout for connection to amps and the headphone out for connection to er.. headphones. I think the dock out is not processed by the circuits designed to provide headphone output (for example the volume is not controlled by the iPhone's volume control which is more convenient). No doubt somebody who can explain it in technical terms will be along soon Laughing 2008 MY Java Black TDV8 HSE
Post #405332 Sun Dec 08 2013 5:49pm
jimbg
I can believe that the volume is higher, so I guess you need less volume on the car and so less distortion?
Haven't a clue really!! Rolling with laughter 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #405335 Sun Dec 08 2013 6:04pm
imb111
2010 Range Rover Sport TDV8 HSE Java Black
I too have the same cable which works perfectly. worth getting a usb>in car charger aswell for a few quid.
Post #405472 Mon Dec 09 2013 7:15pm
