Home > Technical > Switching Off Rear Parking Sensor
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
on my MY06 i could hit a button on the dash to switch off the Reverse Parking sensors, which i always used when i was towing or had a bike rack attached. There is no obvious switch to do this on the MY10 model... is there any short cuts or is it a safety feature that can no longer be disabled Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #344324 Mon May 21 2012 11:21am
With a correctly wired light board (or trailer) plugged in, the rear sensors will dissable automatically (as your 06 should have done) RRS gone
Post #344325 Mon May 21 2012 11:28am
When towing our horse trailer, I noted that the centre sensors are disabled but the outer ones still function. Which is useful as a warning if you get a lot of bend in the rig. 2012 SDV6 - it's missing a couple of cylinders
Post #344326 Mon May 21 2012 12:50pm
Zilch
ah there lies the problem, in OZ the Bike Rack does not have a wired light board, just a number plate.. so nothing plugged in.. hence why the old MY06 RPS warning was so simple to disable by the dash button.. not so on the MY10 Another Pommie Bar Steward down under
Post #344431 Tue May 22 2012 11:45am
I've got an MY12 which (bar some software and a few tweaks here and there) I thought had the same interior as MY10. On my dashboard, there is a button to enable/disable the parking sensors Confused ON THE WAY: BMW F21 M140i
Post #344432 Tue May 22 2012 11:55am
flydive
Do you have the tow electrics installed?
Maybe you could just plug in a dummy plug or a bulb to tell the car you are towing something. '08 RRS TDV8
Post #344434 Tue May 22 2012 12:03pm
garrycol
Australia
Re: Switching Off Rear Parking Sensor
This was covered on AULRO recently and the general consensus was - no (despite the LR Aust site showing a switch on the dash of the cars on their site - apparently does not exist in real life).
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #344435 Tue May 22 2012 12:29pm
Zilch
yep full tow pack Another Pommie Bar Steward down under
Post #344440 Tue May 22 2012 1:01pm
Zilch
garrycol wrote:
This was covered on AULRO recently and the general consensus was - no (despite the LR Aust site showing a switch on the dash of the cars on their site - apparently does not exist in real life). Garry
agree, it is one of those Microsoft moments, "we have improved the experience by removing the simple feature of push the button" Whistle but by all means down load and try and install 15 new plug in's to try and work around it Yawn Another Pommie Bar Steward down under
Post #344443 Tue May 22 2012 1:11pm
mse
You dont have the button in Aus...thats funny, its on the Uk spec 10, 11 and 12...ill see if I can find a picture of the 10 we had with it on. Mike
2014 Facelift Discovery
Post #344477 Tue May 22 2012 10:02pm
Zilch
Picture of my dash, not a RPS cancel button in sight
and the LR Australia site with the offending button 2nd from the left top row on the 2012 Evil or Very Mad ...
http://www.landrover.com/imagery/global/na...le-850x425
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Another Pommie Bar Steward down under
Post #344495 Wed May 23 2012 9:14am
That's amazing (as you say its next to the 'hazard' lights), why remove it for your territory......can you lot be trusted with buttons Whistle Laughing
Sounds like the answer is to plug in something just to keep the system 'happy' ON THE WAY: BMW F21 M140i
Post #344499 Wed May 23 2012 9:52am
Zilch
i can only assume that the ANZ models are Friday afternoon builds, after "Barry from Bromsgrove" had been down the pig and ferret and downed about 16 pints of banks best bitter (extra warm) Laughing and forgot where the RPS button bin is on the assembly line.. Another Pommie Bar Steward down under
Post #344502 Wed May 23 2012 9:57am
Laughing , probably not that far from the truth Thumbs Up ON THE WAY: BMW F21 M140i
Post #344506 Wed May 23 2012 10:07am
mse
Or they cant be trusted with a switch!...i bet the wiring is there though and i equally bet if you plugged in a switch it will work! Mike
Post #344538 Wed May 23 2012 4:08pm
