![]() | Home > Technical > Switching Off Rear Parking Sensor |
| Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835
on my MY06 i could hit a button on the dash to switch off the Reverse Parking sensors, which i always used when i was towing or had a bike rack attached. There is no obvious switch to do this on the MY10 model... is there any short cuts or is it a safety feature that can no longer be disabled Another Pommie Bar Steward down under
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
With a correctly wired light board (or trailer) plugged in, the rear sensors will dissable automatically (as your 06 should have done) RRS gone
ah there lies the problem, in OZ the Bike Rack does not have a wired light board, just a number plate.. so nothing plugged in.. hence why the old MY06 RPS warning was so simple to disable by the dash button.. not so on the MY10 Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
I've got an MY12 which (bar some software and a few tweaks here and there) I thought had the same interior as MY10. On my dashboard, there is a button to enable/disable the parking sensors |
| flydive Member Since: 16 May 2007 Location: South Posts: 1213
Do you have the tow electrics installed?
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
This was covered on AULRO recently and the general consensus was - no (despite the LR Aust site showing a switch on the dash of the cars on their site - apparently does not exist in real life). Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
yep full tow pack Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
agree, it is one of those Microsoft moments, "we have improved the experience by removing the simple feature of push the button" MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
You dont have the button in Aus...thats funny, its on the Uk spec 10, 11 and 12...ill see if I can find a picture of the 10 we had with it on. Mike 2014 Facelift Discovery |
Picture of my dash, not a RPS cancel button in sight
and the LR Australia site with the offending button 2nd from the left top row on the 2012 http://www.landrover.com/imagery/global/na...le-850x425 Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
That's amazing (as you say its next to the 'hazard' lights), why remove it for your territory......can you lot be trusted with buttons |
i can only assume that the ANZ models are Friday afternoon builds, after "Barry from Bromsgrove" had been down the pig and ferret and downed about 16 pints of banks best bitter (extra warm) MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Or they cant be trusted with a switch!...i bet the wiring is there though and i equally bet if you plugged in a switch it will work! Mike
| All times are GMT |
