![]() | Home > Maintenance & Modifications > ECU Remap to lower vehcile (not links) |
anothermoneypit Member Since: 27 Apr 2012 Location: Edinburgh Posts: 91 ![]() ![]() ![]() |
Curious around doing this as stumbled across an ebay ad... wouild be tempted if someone does this locally (Scotland) in the event I wanted to remove the additional lowering capabiliyu - with 22's I do think it sits too high (brutal ride too and even worse once lowered too I imagine )
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Buy one of these:
Strathearn Engineering Member Since: 23 Mar 2012 Location: Aberuthven PH3 1HE Posts: 65 ![]() ![]() |
We can calibrate the suspension to give a lower ride height with our diagnostic machine |
FYI
Thanks for that - having done the links on a vogue not happy with the results (i.e. no control other than manualy changing... in car nice and warm sounds better... will check it out - guessing your right about the ebay chap |
The EAScontrol enables you to lower to the exact mm
Just read up and the maximum drop (to retain acess mode) is actually 18mm not 23mm |
