Home > Maintenance & Modifications > ECU Remap to lower vehcile (not links)
anothermoneypit
Curious around doing this as stumbled across an ebay ad... wouild be tempted if someone does this locally (Scotland) in the event I wanted to remove the additional lowering capabiliyu - with 22's I do think it sits too high (brutal ride too and even worse once lowered too I imagine )
http://www.ebay.co.uk/itm/Range-Rover-Spor...1c25a13585
Link from the bay - anyone in Scotland offer a similar service
Post #342254 Wed May 02 2012 9:48pm
Buy one of these:
http://www.gap-diagnostic.com/products/eascontrol.html
and then you can do it yourself to whatever height you want. And you can undo the changes when you wish.
I'm willing to bet that the guy offering this service at £140 a go is just using one of these types of module. And you'd need to go back to him to get it altered again if required.
If you buy one of these:
http://www.gap-diagnostic.com/products/iidtool.html
then you can do the suspension and general fault stuff too. 2012 SDV6 - it's missing a couple of cylinders
Post #342264 Thu May 03 2012 12:47am
Strathearn Engineering
We can calibrate the suspension to give a lower ride height with our diagnostic machine Thumbs Up
Which part of Scotland are you in? We may be local to you
We are also an authorised Britpart dealer, if you would like to order one of the modules
Mike Strathearn Engineering
Specialising in all things Land Rover + Range Rover
2010MY Range Rover Sport HSE for sale
Group Buy - TDV6 + TDV8 Re-Maps!
TDV6 Silicone Turbo Hose kits for sale
RRS Brake Sale Special Offer!
Post #342266 Thu May 03 2012 6:28am
FYI
-23mm is is maximum if you wish to retain access mode (it will auto select extended mode if any lower than this)
I am on -25mm and have accepted this because it's more of the "look" I wanted and I do not "need" access mode (all my local car parks are 2m height restriction)
Going lower does look better still, but the ride quality dives once past 25mm Mr. Green RRS gone
Post #342279 Thu May 03 2012 9:22am
anothermoneypit
RRSTDV8 wrote:
Buy one of these:
Thanks for that - having done the links on a vogue not happy with the results (i.e. no control other than manualy changing... in car nice and warm sounds better... will check it out - guessing your right about the ebay chap
Post #342316 Thu May 03 2012 11:14am
anothermoneypit
awd man wrote:
FYI
Thanks, sorry can you elabroate (I'm slow!) This ECU modification - any lower than 23mm (assume this is gauged on the screen so I can lower MM by MM ?
Thanks again - agree the 22's with a lower ride height looks really good (appreciate ride Q pish tho...)
Post #342327 Thu May 03 2012 11:54am
The EAScontrol enables you to lower to the exact mm
It's shown on the dash screen Thumbs Up RRS gone
Post #342334 Thu May 03 2012 12:02pm
Just read up and the maximum drop (to retain acess mode) is actually 18mm not 23mm Thumbs Up RRS gone
Post #342340 Thu May 03 2012 12:08pm
