Home > Technical > Heated rear window
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Heated rear window
Hi guys, this hasn't worked for a while and she's nagging me to get it fixed Laughing
Is it a commen problem, easy fix, etc.......
Post #328211 Sun Jan 15 2012 9:20pm
JUCOTT01
Mine broke a while ago,just 1 or 2 lines stopped working
replaced under warranty Very Happy RRS MY11 BALI BLUE OVERFINCH
Post #328215 Sun Jan 15 2012 9:27pm
Big ken
My window won't demist at all, could it be a fuse or the connection to the window.
Post #328216 Sun Jan 15 2012 9:30pm
JUCOTT01
The fuse is a good starting point your manual will help to identify the correct fuse number Thumbs Up
Fuse 15 ,30 Amp (Green) Located behind passenger glove box RRS MY11 BALI BLUE OVERFINCH
Post #328217 Sun Jan 15 2012 9:33pm
Big ken
Post #328218 Sun Jan 15 2012 9:35pm
Johnnyopolis
Big ken wrote:
Mine doesn't work either but I was told by Land Rover that power was getting through so guess i will just need to get a new rear screen...
Post #328231 Sun Jan 15 2012 10:08pm
I have this issue. LR said it was the screen and the LR Approved Warranty doesn't cover "glass". However, my RRS was in a local indie garage yesterday for new brakes and they had a quick look at the screen too. They confirmed that power was getting to the screen and that current can flow across the screen but that the ground/earth side of the circuit was dead. Could be a connection to the screen or a broken wire from the screen onwards. Think I might take it back when they have some time and get them to have a thorough look at it. And if they fix it I shall go back to LR and ask for the £102 they charged me to tell it was broken! 2012 SDV6 - it's missing a couple of cylinders
Post #328425 Tue Jan 17 2012 12:52pm
Often it's as simple as a broken heating element in the window. Do a visual check on the elements and if you find a scratch that might be the problem, you can buy the copper repair paint from all good auto retail stores (And some bad one too!) 2005 Zambezi TDV6 - Gone but not forgotten
Post #328430 Tue Jan 17 2012 1:03pm
True VA, but if the entire screen is refusing to heat then it's not as simple as a single element that's broken. It's almost certainly an issue with the connection to the screen or the wiring serving the screen. 2012 SDV6 - it's missing a couple of cylinders
Post #328435 Tue Jan 17 2012 1:35pm
ARHRRS
Mine has also totally stopped working.
In previous posts it has been mentioned that the wires to the screen where the tailgate opens sometimes break.
Which wires are they? as there are 2 lots of wires when you open the tailgate.
Post #328443 Tue Jan 17 2012 2:27pm
Big ken
I have a scratch in the middle of the screen, will check to see if any of the element is broken.
Would this stop the full window working.
Post #328454 Tue Jan 17 2012 3:56pm
Supacat
Mine broke when the dealer had a company replace the rear tint as it was scratched (but not in the area of the heated elements). They obviously damaged one of the wires and dealer would not correct stating that warranty was voided by aftermarket tint!
Post #328557 Wed Jan 18 2012 10:53am
