| RRSPORT.CO.UK | ||
|  | Home > Technical > Heated rear window |
| JUCOTT01 Member Since: 12 Aug 2010 Location: GLASGOW Posts: 89    | Mine broke a while ago,just 1 or 2 lines stopped working
|  Sun Jan 15 2012 8:27pm |
| Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282      | My window won't demist at all, could it be a fuse or the connection to the window. | ||
|  Sun Jan 15 2012 8:30pm |
| JUCOTT01 Member Since: 12 Aug 2010 Location: GLASGOW Posts: 89    | The fuse is a good starting point your manual will help to identify the correct fuse number  | ||
|  Sun Jan 15 2012 8:33pm |
|  Sun Jan 15 2012 8:35pm |
| Johnnyopolis Member Since: 12 Aug 2011 Location: Hampshire Posts: 137      |
 Mine doesn't work either but I was told by Land Rover that power was getting through so guess i will just need to get a new rear screen... | ||
|  Sun Jan 15 2012 9:08pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | I have this issue. LR said it was the screen and the LR Approved Warranty doesn't cover "glass". However, my RRS was in a local indie garage yesterday for new brakes and they had a quick look at the screen too. They confirmed that power was getting to the screen and that current can flow across the screen but that the ground/earth side of the circuit was dead. Could be a connection to the screen or a broken wire from the screen onwards. Think I might take it back when they have some time and get them to have a thorough look at it. And if they fix it I shall go back to LR and ask for the £102 they charged me to tell it was broken! 2012 SDV6 - it's missing a couple of cylinders
|  Tue Jan 17 2012 11:52am |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | Often it's as simple as a broken heating element in the window.  Do a visual check on the elements and if you find a scratch that might be the problem, you can buy the copper repair paint from all good auto retail stores (And some bad one too!) 2005 Zambezi TDV6 - Gone but not forgotten
|  Tue Jan 17 2012 12:03pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | True VA, but if the entire screen is refusing to heat then it's not as simple as a single element that's broken. It's almost certainly an issue with the connection to the screen or the wiring serving the screen. 2012 SDV6 - it's missing a couple of cylinders
|  Tue Jan 17 2012 12:35pm |
| ARHRRS Member Since: 14 Jan 2010 Location: Birmingham Posts: 36      | Mine has also totally stopped working.
|  Tue Jan 17 2012 1:27pm |
| Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282      | I have a scratch in the middle of the screen, will check to see if any of the element is broken.
|  Tue Jan 17 2012 2:56pm |
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497      | Mine broke when the dealer had a company replace the rear tint as it was scratched (but not in the area of the heated elements). They obviously damaged one of the wires and dealer would not correct stating that warranty was voided by aftermarket tint! | ||
|  Wed Jan 18 2012 9:53am |
| Posting Rules
