![]() | Home > Technical > Transmission Fault |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 ![]() ![]() ![]() |
Hi,
Just take a friend to the airport, parking for about 2 hrs. The battery is about 2 yrs old. the alternator is changed 3 weeks ago. the car seem drive perfect as normal as I try driving all afternoon. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Strange then. I have had fault messages appear and, on turning off the engine and restarting they disappear. It appears to be a RRS thing... 2012 SDV6 - it's missing a couple of cylinders
Just wondering if its time for changing transfer and gearbox oils. I've changed both front and rear diff. oils,timing belt , also blanked off EGR in the summer. |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
i had a problem like this years ago,not a range rover but auto.! problem seemed to be a faulty or sticky valve in the auto-box thats was ment to close when at high speeds on fast roads like motorways,but when around town fault went away as presure was not high or something so was ok.! was a costly job,if had it done but got rid of car.! my advice is do a fast run again and see if problem comes back.? if not then maybe just a glitch.!! |
just seen this first posted 2008.! wish i had seen this before wrote all above |
[quote="mark hamster"]just seen this first posted 2008.! wish i had seen this before wrote all above |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
changed my oil in gearbox much smoother changes and no low end shunt anymore |
so tim,did you fix problem and have you still got same car.? |
~Its still same car |
just out of interest,what was the problem all those years ago.? |
did you do this or was it a garage and if so how much.??? |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Mark - have a read of some of the posts on the Disco site for stories about changing the oil and dropping the sump. Quite an involved process if you want to try and swap the oil 100% but obviously pays dividends for some. |
mark done it at my mates garage
