Home > Technical > Transmission Fault
Tim Hoang
Transmission Fault
On the way back from airport this morning, I saw an 'F' on the gear display and a message saying 'Transmission fault, limited gear selections'. I eased on the pedal to get home and switched the car off. After 1.5 hours, I started the car and drive around, everything seemed to be OK. There's no 'F' nor message.
Anyone experience this before, or any suggestion of what wrong (going to be wrong). Thanks.
Oh, its 2005 TDV6 HSE Auto and done 80KM.
Post #325345 Fri Dec 16 2011 3:05pm
A battery that's on its way out can throw spurious messages/faults. How long had the car been sat at the airport? How old is the battery? 2012 SDV6 - it's missing a couple of cylinders
Post #325360 Fri Dec 16 2011 5:50pm
Tim Hoang
Just take a friend to the airport, parking for about 2 hrs. The battery is about 2 yrs old. the alternator is changed 3 weeks ago. the car seem drive perfect as normal as I try driving all afternoon.
Post #325363 Fri Dec 16 2011 7:03pm
Strange then. I have had fault messages appear and, on turning off the engine and restarting they disappear. It appears to be a RRS thing... 2012 SDV6 - it's missing a couple of cylinders
Post #325369 Fri Dec 16 2011 8:12pm
Tim Hoang
Just wondering if its time for changing transfer and gearbox oils. I've changed both front and rear diff. oils,timing belt , also blanked off EGR in the summer.
Post #325373 Fri Dec 16 2011 8:39pm
mark hamster
i had a problem like this years ago,not a range rover but auto.! problem seemed to be a faulty or sticky valve in the auto-box thats was ment to close when at high speeds on fast roads like motorways,but when around town fault went away as presure was not high or something so was ok.! was a costly job,if had it done but got rid of car.! my advice is do a fast run again and see if problem comes back.? if not then maybe just a glitch.!!
Post #325380 Fri Dec 16 2011 11:42pm
mark hamster
just seen this first posted 2008.! wish i had seen this before wrote all above Big Cry . anyway quick question,thought auto box oil is sealed and dont need changing.? or is it good idea after so many miles to change..?
Post #325381 Fri Dec 16 2011 11:45pm
Tim Hoang
[quote="mark hamster"]just seen this first posted 2008.! wish i had seen this before wrote all above Big Cry . anyway quick question,thought auto box oil is sealed and dont need changing.? or is it good idea after so many miles to change..?[/quot
Don't believe in the' Sealed for Life' thing, it's better to change it after such milages. Although, it's not easy I believe.
Post #325383 Sat Dec 17 2011 1:02am
airwolf222helicopters
changed my oil in gearbox much smoother changes and no low end shunt anymore Thumbs Up
sealed for life = 3 yrs according to landrover if warrenty issue ?
look on forum alot of history of people talking of same issue Thumbs Up
Post #325406 Sat Dec 17 2011 11:16am
mark hamster
so tim,did you fix problem and have you still got same car.?
Post #325409 Sat Dec 17 2011 11:23am
Tim Hoang
~Its still same car
Post #325428 Sat Dec 17 2011 3:32pm
mark hamster
just out of interest,what was the problem all those years ago.?
Post #325453 Sat Dec 17 2011 11:48pm
mark hamster
did you do this or was it a garage and if so how much.???
Post #325454 Sat Dec 17 2011 11:49pm
Supacat
Mark - have a read of some of the posts on the Disco site for stories about changing the oil and dropping the sump. Quite an involved process if you want to try and swap the oil 100% but obviously pays dividends for some.
Post #325470 Sun Dec 18 2011 10:04am
mark done it at my mates garage
took two hours
remember to save all the oil you take out so u know how much to put back
lr say 7 ltrs
4.5 back in mine alot of oil stays in transfer box
bit tricky filling need a hand Thumbs Up pump
Post #325500 Sun Dec 18 2011 5:18pm
