Home > Technical > Is this a problem?
rm0rgan
Is this a problem?
I have just noticed that the tyres on my 57 plate RRS TDV8 seem at odds to the handbook...
The car had 2 new tyres fitted by the dealer when I collected it (275/45/20) whereas the handbook lists the sizes as 275/40/20 - they are also 275/45/20 on the rears so at least they are all the same size - I just find it odd the dealer would put a non specified size on the car.
So, 2 questions.
Should I be concerned?
What pressures should I run in these (car normally transports 2 adults, 2 kids + dog and other rubbish?
Thanks kindly Thumbs Up Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
My Car: Lotus Exige S2 PP & TP Smile)
Post #319265 Sun Oct 30 2011 4:17pm
C10KO
Generaly no issue with the larger size tyres. But if it was me I would be requesting a correct size dimension from the dealer...
Post #319266 Sun Oct 30 2011 4:30pm
rm0rgan
Thank you - I think I will take it up with them.
In researching, I just came across this handy little website that visually shows you the differences a change in profile makes - very interesting. http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
I'm guessing that having a taller profile actually makes the ride a little softer (at the detriment to handling).
Thanks for the reply so quickly - interested in whether anyone else is running these sizes - a search suggest not Shocked Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #319267 Sun Oct 30 2011 4:37pm
C10KO
Some people on here do and they report good feedback. The size dim is equal to 255/55/19 which LR used for the G4 vehicles so there should be no technical problem but can see it being an issue if you happen to be in e.i. an insurance or waranty situation.
Post #319269 Sun Oct 30 2011 4:59pm
rm0rgan
Good point ref insurance - I will ask the question.
I've already had some warranty work done (ARB Bushes and Mass Damper kit) all fitted under warranty and in fact is back again tomorrow for 3 days for an intermittent Suspension fault (they think one of the bags are leaking and need to disconnect everything apparently to see which is at fault - personally I think they don't have a clue as its been back twice already!)
Still, lets see in 3 days whether they get it fixed this time - 3rd time lucky and all that Confused Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #319275 Sun Oct 30 2011 5:30pm
mse
I noticed a few sites arent listing the correct size but do the size you had fitted...dont know why but i did wonder what would happen if i needed a tyre Mike
2014 Facelift Discovery
Post #319279 Sun Oct 30 2011 6:12pm
Supacat
Interesting websire, note it also states:
Note: Changing your wheels/tyres will affect your speedometer reading!
• When your speedo reads 60mph you will actually be doing 69.9mph.
Post #320929 Sat Nov 12 2011 8:16pm
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
Rolling with laughter
its not quite as much as that,if you are doing 30mph you will actually be doing 31.1mph & if your doing 60mph you will be doing 62.3mph,but speedo's are slightly out anyway so it wont make that much differance.
check on here http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
i use it all the time when people are putting after market alloys on their cars.
Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
1980 Rolls Royce,shadow 2 in white.
Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's.
Gone 02/52 FFRR vogue.
Post #320961 Sun Nov 13 2011 10:31am
Interesting site. Like the calculator. Particularly like that 255/50/19 is actually slightly larger in diameter than 275/40/20. People put 20s on to "fill the arches" etc but they actually don't. Got to laugh! Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #321000 Sun Nov 13 2011 4:43pm
V8 andy
The reason they fill the arches is because they are wider, Rolling with laughter Rolling with laughter
Post #321003 Sun Nov 13 2011 5:33pm
Supacat
It is - if you click the link above and use the example tyre change on the same web site you quote Wink
Post #321004 Sun Nov 13 2011 5:36pm
V8 andy
so you are saying a 275/40/20 is doing 60 the 275/45/20 will be doing 69 when speedo shows 60 Laughing dont think so its only a couple of mph out.
Post #321007 Sun Nov 13 2011 5:50pm
Supacat
Andy.
No Yawn
click the link you posted and a worked example popos up - 14" to 17" and thosearethe figs I quote as an example of the issue...
Post #321502 Thu Nov 17 2011 7:59am
