![]() | Home > Technical > Is this a problem? |
| C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136
Generaly no issue with the larger size tyres. But if it was me I would be requesting a correct size dimension from the dealer... |
| rm0rgan Member Since: 04 Jun 2011 Location: Ross on Wye Posts: 42
Thank you - I think I will take it up with them. In researching, I just came across this handy little website that visually shows you the differences a change in profile makes - very interesting. http://www.kouki.co.uk/utilities/visual-tyre-size-calculator I'm guessing that having a taller profile actually makes the ride a little softer (at the detriment to handling). Thanks for the reply so quickly - interested in whether anyone else is running these sizes - a search suggest not My Car: Lotus Exige S2 PP & TP |
Some people on here do and they report good feedback. The size dim is equal to 255/55/19 which LR used for the G4 vehicles so there should be no technical problem but can see it being an issue if you happen to be in e.i. an insurance or waranty situation. |
Good point ref insurance - I will ask the question.
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
I noticed a few sites arent listing the correct size but do the size you had fitted...dont know why but i did wonder what would happen if i needed a tyre Mike
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497
Interesting websire, note it also states:
| V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540
its not quite as much as that,if you are doing 30mph you will actually be doing 31.1mph & if your doing 60mph you will be doing 62.3mph,but speedo's are slightly out anyway so it wont make that much differance. check on here http://www.kouki.co.uk/utilities/visual-tyre-size-calculator i use it all the time when people are putting after market alloys on their cars. Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof. 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9156
Interesting site. Like the calculator. Particularly like that 255/50/19 is actually slightly larger in diameter than 275/40/20. People put 20s on to "fill the arches" etc but they actually don't. Got to laugh! |
The reason they fill the arches is because they are wider, Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof. 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
It is - if you click the link above and use the example tyre change on the same web site you quote |
so you are saying a 275/40/20 is doing 60 the 275/45/20 will be doing 69 when speedo shows 60 Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof. 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
No click the link you posted and a worked example popos up - 14" to 17" and thosearethe figs I quote as an example of the issue... |
| All times are GMT |
