Home > Maintenance & Modifications > Gearbox oil change!
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Gearbox oil change!
Any one out there changed their gearbox oil? what mileage to change? 06 s/c...or are the gearboxes sealed for life? Thanks
Post #304089 Mon Jun 27 2011 1:45pm
shepp
Hello SCdavies
I am going to change mine when i can get the time and dig up the info.
It is recommended by landrover that the gear oil is changed every 10 years 150K
If you search for drive line shunt you may find more info, as some of the recomendations were to change it
Post #304146 Mon Jun 27 2011 7:36pm
SCdavies
Many thanks for the info.
Post #304211 Tue Jun 28 2011 6:53am
airwolf222helicopters
i changed mine on my o7 Thumbs Up easy to do oil bit trumpy tho and its main dealer only special type if you dont use the specifide type it curdles
Post #304330 Tue Jun 28 2011 8:43pm
shepp
any info on capacity Thumbs Up
Post #304338 Tue Jun 28 2011 9:25pm
ok the gearbox so ive been told at dealer holds 7ltrs
but when i drained gearbox i only captured about 4.5 ltrs beacuase aparently in all the nooks ie the transfer box etc holds all the others ltrs
i only managed to get 4.0 ltrs back in
i took for a spin then rechecked oil level and topped up 0.5 ltrs
took for another spin up on ramp again level was ok
others on here didnt get 4.5 ltrs in only 2-3 some have said so try to capture the old oil and measure it before you refill
Post #304342 Tue Jun 28 2011 9:45pm
My dealer told me you have to drop the oil twice to do it properly, at a cost of around £450 in total Shocked he said the oil is around £28 per litre Big Cry
Post #304343 Tue Jun 28 2011 9:49pm
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hmmm my dealer told me I needed new discs and pads all round..... 12,000 miles ago! I am happy to do that job myself so said 'no thanks' and have been keeping a close eye ever since but all's still fine. Funnily enough, I have trouble believing anything he says now.
J
Post #304365 Wed Jun 29 2011 5:54am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
In Australia many have independents have debunked the sealed for life or 10 years and are changing the transmission fluid at approx 80-90K KM's, along with the diffs and transfer box. It is strongly recommended to flush the gearbox with clean fluid first, so hence why expensive, your dealer was correct this time Wink
On my MY05 I had the transmission/diff/transfer box oils changed on its 96K service, it was a lot smoother thereafter , it cost approx 600 UK (950 Aussie) including a major service Thumbs Up Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #304380 Wed Jun 29 2011 9:31am
Eclayson
Although five years late I've just done a gearbox fluid and filter replacement on a RRS SC and its ridiculous.
Due to a protrusion from the filter pan (which includes the filter) the following was removed to get the thing off
Cross member
Cats
Engine mounts
Gearbox mount
Propshaft ( yes for one supid bolt)
Various shields
Once all that's done you'll still struggle to get the pan out. We have to give it a tug and the protrusion snapped enabling removal. Thankfully the new pan has more compliance but what a mission.
Hope this helps
Post #475212 Sun Oct 04 2015 9:16am
gogsy1956
Are we not all talking about a gearbox flush or megaflush as it is more commonly referred to, So many threads on here about this subject, as mentioned a simple drain and refill only drains half the oil from the Gearbox which is why a special machine is used to carry out this process. Thiis normally recommended to be carried out at the 70k mark 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #475295 Sun Oct 04 2015 9:03pm
Eclayson
As far as I'm aware the gearbox fluid should be changed along with the filter in the pan. The pan removal is the nightmare. Not changing this seems somewhat odd as you wouldn't change the engine oil without the filter also, so why the gearbox.
Post #475331 Mon Oct 05 2015 9:13am
Lost for Words
A flush is recommended by ZF at 50-75k. Thumbs Up
FWIW, the filter is often not considered worth changing (because it's only really a strainer), so my view is that the best course of action is either flushing as above, or more frequent simple drain and re-fills, and not to worry about the filter for a long time. Wink
Since the new TC was fitted, I'll be doing a basic change on mine yearly (between 20 and 25k). Thumbs Up Visiting from DISCO3.CO.UK
Post #475333 Mon Oct 05 2015 9:19am
Eclayson
Apologies for disagreeing but if you take the transmission pan off you will see why replacement is suggested. My advice is to replace the pan at the suggested intervals.
Post #475341 Mon Oct 05 2015 9:47am
Lost for Words
The suggested interval is 150k, so TBH, I don't think that's entirely contrary to my suggestion, though I would be thinking of maybe 200k (time factor to be considered also, however). I believe the experience of those such as Geoff and Disco Mikey is that the filters are spotless, even on high mileage vehicles, unless the gearbox has become damaged. Thumbs Up Visiting from DISCO3.CO.UK
Post #475347 Mon Oct 05 2015 11:30am
