![]() | Home > Maintenance & Modifications > Gearbox oil change! |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441
Hello SCdavies
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324
Many thanks for the info. |
| airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248
i changed mine on my o7 |
any info on capacity |
ok the gearbox so ive been told at dealer holds 7ltrs
My dealer told me you have to drop the oil twice to do it properly, at a cost of around £450 in total |
| Jmac Member Since: 17 Feb 2011 Location: South Posts: 125
Hmmm my dealer told me I needed new discs and pads all round..... 12,000 miles ago! I am happy to do that job myself so said 'no thanks' and have been keeping a close eye ever since but all's still fine. Funnily enough, I have trouble believing anything he says now. J |
| Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835
In Australia many have independents have debunked the sealed for life or 10 years and are changing the transmission fluid at approx 80-90K KM's, along with the diffs and transfer box. It is strongly recommended to flush the gearbox with clean fluid first, so hence why expensive, your dealer was correct this time |
| Eclayson Member Since: 04 Oct 2015 Location: Sussex Posts: 4 |
Although five years late I've just done a gearbox fluid and filter replacement on a RRS SC and its ridiculous.
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
Are we not all talking about a gearbox flush or megaflush as it is more commonly referred to, So many threads on here about this subject, as mentioned a simple drain and refill only drains half the oil from the Gearbox which is why a special machine is used to carry out this process. Thiis normally recommended to be carried out at the 70k mark 2010 RRS, TDV8
As far as I'm aware the gearbox fluid should be changed along with the filter in the pan. The pan removal is the nightmare. Not changing this seems somewhat odd as you wouldn't change the engine oil without the filter also, so why the gearbox. |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
A flush is recommended by ZF at 50-75k. |
Apologies for disagreeing but if you take the transmission pan off you will see why replacement is suggested. My advice is to replace the pan at the suggested intervals. |
The suggested interval is 150k, so TBH, I don't think that's entirely contrary to my suggestion, though I would be thinking of maybe 200k (time factor to be considered also, however). I believe the experience of those such as Geoff and Disco Mikey is that the filters are spotless, even on high mileage vehicles, unless the gearbox has become damaged. |
| All times are GMT |
