![]() | Home > Technical > Passenger side front door latch |
| marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68
Has any one got any info on changing the passenger door latch. Not quite sure how to take the inside door cover of
| RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176
This one is for the rear. Hope it helps
Thanks very much Pat i think after looking at those photos ill get a mechanic to do it. Ill f**k it up proberbly. |
Not sure what exactly the problem you have is. I had the link to hand as my rear passneger door would only open intermittently and I guessed it was the motor. Rather than a trip to the dealer changing the key fob from only open drivers door on first click to open all doors made the problem go away and door opens every time. if your problem is similar may be worth a go? 2011 Autobiography Santorini Black |
cheers illl try it |
