Home > Technical > Passenger side front door latch
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Has any one got any info on changing the passenger door latch. Not quite sure how to take the inside door cover of
then whats involved in changing the latch is there a diagram anyware?????? Confused
Post #301226 Mon May 30 2011 3:04pm
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
This one is for the rear. Hope it helps
http://www.disco3.co.uk/forum/topic33743.html?highlight= 2011 Autobiography Santorini Black
Post #301228 Mon May 30 2011 3:37pm
I know when i had my drivers door latch replaced, the technician said they are a pig to do. You need small hands apparently.
Post #301233 Mon May 30 2011 4:21pm
marksgd
Thanks very much Pat i think after looking at those photos ill get a mechanic to do it. Ill f**k it up proberbly. Wink
Post #301236 Mon May 30 2011 4:49pm
RRS_PAT
Not sure what exactly the problem you have is. I had the link to hand as my rear passneger door would only open intermittently and I guessed it was the motor. Rather than a trip to the dealer changing the key fob from only open drivers door on first click to open all doors made the problem go away and door opens every time. if your problem is similar may be worth a go? 2011 Autobiography Santorini Black
Post #301305 Tue May 31 2011 8:34am
marksgd
cheers illl try it Wink
Post #301318 Tue May 31 2011 11:18am
