![]() | Home > General > Hosepipe ban and RRS washing |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
Nice will have to look in to this |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
My old man had a water butt set up but the water was always horribley dirty.
Sand and water not good sod that then RRS TDV6 Gone but still around
Bobs_buggy Member Since: 30 Apr 2006 Location: Pump No.3, usually! Posts: 213 ![]() ![]() ![]() |
Absolutely not, I clean the barrels out every 3-4 years, and the water is crystal clear. The sand and grit all falls to the bottom of the barrel, and because the tap outlet is 6" above this, it never draws any of the sediment out. Just to make sure, I have a garden water filter in the output hose which I rinse out from time to time, but it doesn't really get dirty.
Fair play mate! I'll bow to your superior knowledge on butts! |
.....I'm a boobie man myself... |
Someone say butts |
Yes........very good |
Are commercial car wash machines permitted to operate? They don't generally use hoses.......... although personally I wouldn't take any car of mine anywhere near one of those machines with the rotating brush systems. You will have to come to Scotland for a weekend break and wash the car at the same time, no shortage of water up here 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
noddy and bigears Member Since: 05 Nov 2005 Location: hants Posts: 116 ![]() ![]() |
now then children you might learn something have you ever seen the man with the big long pole cleaning windows....... he only uses filtered water the windows are not wiped afterwards...because the water is filtered there are no streaks .... tap water has a lot of impuritys etc...which leave streaks unlike pure rainwater... we use a rainwater tank to feed a pressure washer in a similer way due to low water pressure.... rainwater is free |
ALL water belongs to the water companies and even if you collect it in the above way using a hosepipe is banned! I think |
no any water that does not come from the drinking water supply can be used |
OK stand corrected! Isn't it stupid that if I have a bath I can't then use a hose from the bath to water the garden! 2005 Zambezi TDV6 - Gone but not forgotten
Use a jug |
