![]() | Home > Technical > Power Steering problem |
Has the car always been main dealer serviced? If not, it could be that your PS Hydraulic Fluid is tired and needs to be changed, the other thing is, is the car on OEM 19"/20" wheels and tyres? If you have been running on anything else like 21's or bigger and your car doesn't have the uprated steering pump that allowed bigger wheels to be fitted on earlier cars then you may have worn out the pump 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
jonnyburke Member Since: 30 Oct 2009 Location: Glasgow Posts: 17 ![]() ![]() |
Yeah it was serviced in feb,
Is there a specific type of fluid that the sport takes?
The fluid will be listed in your owners manual John, in these modern times I wouldn't use anything else except the recommended PS top up fluid. If you don't fancy main dealer labour prices (and I also assume that as yours is a 2006model you don't have any warranty left!) then there are 2 well regarded non franchise specialists in Central Scotland - one at Larbert and the other in Aidrie who will be able to tell you if your pump is shot and whether or not you have the lower rated of the two puumps (they all have the uprated pump from 2007 anyway). There are posts on here that tell you how to tell an uprated from a lower rated pump/ steering rack. Earlier today I posted the two companies above on another thread, they both use genuine Land Rover parts and somehow manage to sell them at lower prices than the dealership accessories departments and their labour is generally 50% of a main dealers and sometimes even less!
Top man,
If you use the search for "steering rack" you will find out how to tell if you already have the uprated system or the old lower rated one........................................ or if you are really lucky Bobby will come along and post it for you |
...and if you "searched", you'd have found THIS, which explains what Tim is talking about. |
