Home > Technical > rear view mirrors dip?? HELP!!
antrrs
Hi, can anyone please tell me how to set my rear view mirrors to dip when I'm reversing? I've not had my manual yet from the previous owner!
Many thanks,
Ant.
Post #257739 Mon Mar 01 2010 11:10pm
Tim in Scotland
You don't need to "set" them, they just do it if the system is working OK!! You can download the owners manual for your model year in PDF format from the Land Rover UK website. Sounds like a trip to a dealer might be needed to trace the fault 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257740 Mon Mar 01 2010 11:13pm
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
Tim, sorry to disagree, but there is a personal preference setting throught the 'i' button - with the ignition on, but engine off, press the end of the left had stalk to access tyhe 'i' settings - step through with the controls on the right hand side of the steering wheel. This gives you many options including reverse mirror dipping (which I have to say I turned off as I need to miss the gate posts when I reverse out of my garage!)
Post #257747 Mon Mar 01 2010 11:25pm
Tim in Scotland
Embarassed Embarassed Well there you go, mine have always worked and I have never needed to do anything to them! I would prefer it if the driver's side didn't dip but there you go. Sorry for the misleading info must get the manaul out again sometime! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257756 Mon Mar 01 2010 11:52pm
tornado34
Also just remembered, if when you are in reverse and the mirror's have dipped, if you adjust them whilst still in reverse and set your drivers seat memory they will be remembered. Therefore, just adjust your drivers mirror to 'normal' when in reverse and you should fix your wish Tim Thumbs Up
Post #257757 Mon Mar 01 2010 11:56pm
NasMan
The only way to remember the setting is to set them whilst the engine is OFF in position II. An then save memory position. The next time you select reverse when the vehicle is on, the mirrors will dip to the correct position..
Tim - you can use the same technique to NOT have the driver's mirror dip, as they can be set indepedantly.. 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys
Bought in Januray 2010. Colour Coded Car with Forum Members Help.
CURRENT - 2004 Mercedes SL350 | Silver - Best Car I have ever had Smile
GONE - Jaguar S-Type | Silver
Post #257765 Tue Mar 02 2010 1:27am
Bradders
Just tried this myself as both mirrirs dipped when reversing - very off putting. I adjusted the drivers mirror back to its normal position while in reverse, selected memory one and its has stored the adjusted mirror position so when reversing, the drivers side mirror doesnt move but the nearside does, so I can see the kerb. Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #257844 Tue Mar 02 2010 6:55pm
NasMan
Weird thing is - I think it was Tim that told me in the first place... Maybe he is less steady when he is on terra firma..? 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys
Post #257849 Tue Mar 02 2010 7:02pm
Tim in Scotland
Lol, memory is failing with advancing age! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257853 Tue Mar 02 2010 7:13pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
i tried that and it didnt work so i just switched em off Laughing
Post #257866 Tue Mar 02 2010 7:58pm
