![]() | Home > Technical > Snow Program |
| Mail Order Ride Member Since: 28 Feb 2009 Location: UK Posts: 131 |
Sorry - thread hijack |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554
No, just drive according to the conditions on the road, and the type of tyres you have. |
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382
Without wanting to sound rude, suggest you go on a Land Rover Experience (or similar) event to get some off road driver training..! |
| ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750
I noticed the vanishing wheels as well
| Jonnylp Member Since: 18 Sep 2008 Location: Cheshire Posts: 78
Thanks for the swift responses, to be honest I think I will book on one of the LR off road courses as even if I learn things I cant use afterwards it will be fun I guess !!
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
It to show which way your tyres are turned. Basically if your going down a muddy slope/rut and you have been trying to brake using the sidewalls on the rut sides you could have come to a stop with your wheels point in any old direction, this is to let you know which way your pointing, so when you then apply the gas your cars going to go in the direction its showing you, not the direction you think it would Sure somebody has another explanation which might make more sense |
Thanks for the replies too |
| NickM Member Since: 14 Feb 2008 Location: London Posts: 2995
Not meaning to hijack the original - but this is kinda linked - snow program has been great - but can you change back to normal whilst in motion? 2 times I have used it - and gone back to normal - I have lost all power when in gear - it has needed me to restart the car and then all works fine again.....any ideas?? |
| ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704
yea nick i found the same. Usually come off the gas and turn the know to the left twice to make sure its off. Then its usually cool. WINNER - 2008 Best All New Photograph
Strange you should be able to switch programs without any issues described |
Sounds like a software issue - definitely not normal. |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476
Have had no problems tonight driving 90 odd miles on snow bound motorways at up to 50mph in GGS and then switched back to normal highway mode. The damping sensation of the remapped ECU takes a bit of getting used to as you seem to have to push the gas pedal an awful long way before anything seems to happen, but it worked faultlessly when changing back and forth between GGS and highway/normal mode. I didn't need Low box at all, in fact I think you would have to be really stuck to need to use Low box in snow, I appreciate that offroad on grass and gravel then yes Low Box would be a must.
You can switch between the various special programs whilst driving and even high/low range (low speed), you must have a problem |
Ash I wouldn't try changing from Hi to Lo box at anything above 15mph, I think you would leave a lot of cogs on the road under the car! I think the electronics won't allow you to shift Hi to Lo anyway above 15mph.
| All times are GMT |
