Home > Technical > Snow Program
Jonnylp
Snow Program
Is there a recommended maximum speed limit whilst using this program ?
I know on other programs there is a need to select Lo but not with the above ?
Thanks
Post #246103 Mon Dec 21 2009 10:28am
Mail Order Ride
Sorry - thread hijack Smile
I was using GGS yesterday in low range and noticed occasionally that the LCD display under my clocks would show a steering wheel icon and which way my wheels were pointing (a simplified version of the satnav screen on off road mode)
Why does it sometimes do this?
I was trying to work out if it was related to losing traction but in the end didnt think so
Cheers!
Post #246110 Mon Dec 21 2009 11:20am
Leo
Kenya
No, just drive according to the conditions on the road, and the type of tyres you have.
Post #246111 Mon Dec 21 2009 11:21am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Mail Order Ride wrote:
I was trying to work out if it was related to losing traction but in the end didn't think so
Without wanting to sound rude, suggest you go on a Land Rover Experience (or similar) event to get some off road driver training..! Thumbs Up
Post #246115 Mon Dec 21 2009 11:25am
ASH555
England 2010 Range Rover Sport 3.0 TDV6 HSE Zermatt Silver
I noticed the vanishing wheels as well
With regards to speed limit, i don't think it maters the mapping will only let you drive the car as the setting allows Thumbs Up
Hope you have all been practising that smug look when passing all those 'green' cars stuck by the road (we need a new emoticon - SMUG) MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Gone 2006 '56' 2.7 TDV6 HSE, Zermatt Silver, 20", Side Steps, Brembos, Dynamic Pack, Etc
VW Transporter, 19" Rims, T32 170 BHP, Lowered
Post #246116 Mon Dec 21 2009 11:25am
Jonnylp
Thanks for the swift responses, to be honest I think I will book on one of the LR off road courses as even if I learn things I cant use afterwards it will be fun I guess !!
Regards
Post #246121 Mon Dec 21 2009 11:42am
Cheers!
It to show which way your tyres are turned.
Basically if your going down a muddy slope/rut and you have been trying to brake using the sidewalls on the rut sides you could have come to a stop with your wheels point in any old direction, this is to let you know which way your pointing, so when you then apply the gas your cars going to go in the direction its showing you, not the direction you think it would
Sure somebody has another explanation which might make more sense Laughing , but that's why it there, its in other programs too Thumbs Up
Post #246131 Mon Dec 21 2009 1:23pm
Mail Order Ride
Thanks for the replies too Smile
2nd Rower
Fair comment, however since Ive had the car Ive done my best to provoke it, even on severe split mu surfaces, and have so far failed to get the traction control light on - although I eventually managed it tonight on sheet ice Mr. Green
Which explains how I came to be unsure if Id ever lost traction before or not and as it turned out I never had previously
Thanks for the advice but again today I get the display taken over seemingly randomly, it is only there now and again and definitely not all the time
Putting the two together I had assumed I get the LCD wheel alignment display when the cars losing traction, however I had never previously managed to light the traction control lamp until I did today under (severe) provocation
So my question remains when exactly does the LCD display get taken over light this - it cannot be random Im sure
Cheers Thumbs Up
Post #246346 Tue Dec 22 2009 8:05pm
NickM
Not meaning to hijack the original - but this is kinda linked - snow program has been great - but can you change back to normal whilst in motion? 2 times I have used it - and gone back to normal - I have lost all power when in gear - it has needed me to restart the car and then all works fine again.....any ideas??
Post #246363 Tue Dec 22 2009 9:06pm
ViewWise
yea nick i found the same. Usually come off the gas and turn the know to the left twice to make sure its off. Then its usually cool. WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #246365 Tue Dec 22 2009 9:30pm
Strange you should be able to switch programs without any issues described
Post #246366 Tue Dec 22 2009 9:39pm
Leo
Kenya
Sounds like a software issue - definitely not normal.
Post #246367 Tue Dec 22 2009 10:00pm
Tim in Scotland
Have had no problems tonight driving 90 odd miles on snow bound motorways at up to 50mph in GGS and then switched back to normal highway mode. The damping sensation of the remapped ECU takes a bit of getting used to as you seem to have to push the gas pedal an awful long way before anything seems to happen, but it worked faultlessly when changing back and forth between GGS and highway/normal mode. I didn't need Low box at all, in fact I think you would have to be really stuck to need to use Low box in snow, I appreciate that offroad on grass and gravel then yes Low Box would be a must.
I must admit my biggest worry tonight was the thought that at any minute my 20" tyres would get their treads clogged up and become slicks but they too worked faultlessly even at 2 years old with 23000 miles on them and 4mm of tread left the car felt assured and confidence inspiring and not once did I hear the taktaktak of the TC cutting in or see the flashing TC light come on in the whole trip. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #246381 Tue Dec 22 2009 10:57pm
ASH555
You can switch between the various special programs whilst driving and even high/low range (low speed), you must have a problem Confused MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Post #246411 Wed Dec 23 2009 8:26am
Tim in Scotland
Ash I wouldn't try changing from Hi to Lo box at anything above 15mph, I think you would leave a lot of cogs on the road under the car! I think the electronics won't allow you to shift Hi to Lo anyway above 15mph.
BTW Is everybody aware that you can adjust the HDC speed using the cruise control +/- key? Never run with HDC swicthed on any longer than you need as it will eat your brake disks and pads if it operates too frequently! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #246425 Wed Dec 23 2009 11:25am
