Home > Technical > Passenger seat belt alert
Killerbob
Switzerland 2009 Range Rover Sport TDV8 HSE Java Black
Hi,
I have noticed that if I have been driving my wife to work, she gets out, and the passenger seat belt alert comes on. She is no longer in the seat, and of course the seat belt is unbuckled. If I then give the passenger seat a good whack, it goes away.
Is this a trip to the stealer and a new sensor?
KB RRS TDV8, black with ivory.
Post #210107 Thu Feb 05 2009 7:55pm
MAW
I guess - or get the missus to sit in the back Laughing
Post #210110 Thu Feb 05 2009 8:09pm
klm
2008 Range Rover Sport TDV8 HSE Stornoway Grey
It's more bloody annoying when you have a water bottle or laptop on the seat and it keeps flashing Evil or Very Mad
Post #210112 Thu Feb 05 2009 9:01pm
MAW
and bonging Evil or Very Mad friend of mine bought a buckle from a scrap yard to 'turn off' the feature in his car Laughing
Post #210113 Thu Feb 05 2009 9:04pm
Killerbob
...but it sounds like a bad sensor, right? RRS TDV8, black with ivory.
Post #210118 Thu Feb 05 2009 10:20pm
MAW
Sounds like it
Post #210119 Thu Feb 05 2009 10:34pm
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
You can also stop the sound definitly:
Key in ignition, turn to switch electricks on. Sit in seat and put buckle in the buckle lock 9 times within a minute. After the ninth time a bong will sound and it's sorted. Do the reverse to reset!
Source: http://rrsport.co.uk/forum/topic5753.html?highlight=
It was definitly working on cars 2/3 years old, not sure about the newer ones Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #210148 Fri Feb 06 2009 10:32am
MAW
Doesn't work on the newer ones - cannot recall MY think it may be MY8.5 onwards
Post #210150 Fri Feb 06 2009 10:36am
Jimmy_75000
too bad... Confused Range Rover Vogue ‘17 TDV6
Post #210157 Fri Feb 06 2009 11:38am
RRSKildare
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
Hi There,
Mine was doing the same - left it under warranty and it has been resolved. Not sure what they did though.
Regards,
Ken
Post #210161 Fri Feb 06 2009 11:45am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
I had the same problem a while back. You have a faulty pressure sensor under the passenger seat cushion. Your local dealership should replace the seat cushion under warranty. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #210188 Fri Feb 06 2009 2:38pm
Jonny Fresh
worked on mine and mine is an 08 plate.......you need the key turned to 1st ignition point
Post #210190 Fri Feb 06 2009 2:44pm
Bobby
The pressure switch in the occupant detection system (except NAS vehicles) which determines if the front passanger seat is occupied or not could be faulty/stuck . It is installed between the foam padding and the cover of the seat cushion.
The pressure switch incorporates a number of load cells connected in series and embedded in a plastic film. Weight on the pressure sensor increases the resistance of the circuit.
The instrument cluster supplies a reference voltage to the pressure switch and measures the current draw to determine the occupancy status. From the occupancy status, and the status of the front passenger safety belt (received from the RCM (restraints control module) on the high speed CAN (controller area network) bus), the instrument cluster determines the belt minder status.
That's how this works! Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #210200 Fri Feb 06 2009 3:18pm
Bobby
It does work even on newer ones...
The belt minder function can be enabled and disabled using the driver safety belt switch. The instrument cluster changes the state of the belt minder function if, within 60 seconds of first turning the ignition switch to position II, the driver safety belt is fastened and unfastened nine times. Successful completion of the change is indicated by a single chime and the safety belt warning indicator flashing five times, at 2 Hz. The belt minder function can also be enabled and disabled using T4.
Wink Thumbs Up Malaysia Boleh!
Post #210305 Sat Feb 07 2009 5:21am
MAW
Bobby - if that works Thumbs Up once again !!!!!!!! Tried it the old way (as per last RRS) and it didn't work - will try this!!
I assume T4 is the diag port hookup??
Post #210319 Sat Feb 07 2009 10:07am
