Home > Technical > Passenger seat belt alert |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
I guess - or get the missus to sit in the back |
Thu Feb 05 2009 8:09pm |
klm Member Since: 30 May 2006 Location: UK Posts: 155 |
It's more bloody annoying when you have a water bottle or laptop on the seat and it keeps flashing |
Thu Feb 05 2009 9:01pm |
and bonging friend of mine bought a buckle from a scrap yard to 'turn off' the feature in his car |
Thu Feb 05 2009 9:04pm |
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 |
...but it sounds like a bad sensor, right? RRS TDV8, black with ivory. |
Thu Feb 05 2009 10:20pm |
Sounds like it |
Thu Feb 05 2009 10:34pm |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
You can also stop the sound definitly:
Fri Feb 06 2009 10:32am |
Doesn't work on the newer ones - cannot recall MY think it may be MY8.5 onwards |
Fri Feb 06 2009 10:36am |
too bad... Range Rover Vogue ‘17 TDV6
Fri Feb 06 2009 11:38am |
RRSKildare Member Since: 27 Jun 2008 Location: Kildare Posts: 6 |
Hi There,
Fri Feb 06 2009 11:45am |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
I had the same problem a while back. You have a faulty pressure sensor under the passenger seat cushion. Your local dealership should replace the seat cushion under warranty. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Fri Feb 06 2009 2:38pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
worked on mine and mine is an 08 plate.......you need the key turned to 1st ignition point |
Fri Feb 06 2009 2:44pm |
The pressure switch in the occupant detection system (except NAS vehicles) which determines if the front passanger seat is occupied or not could be faulty/stuck . It is installed between the foam padding and the cover of the seat cushion.
Fri Feb 06 2009 3:18pm |
It does work even on newer ones... The belt minder function can be enabled and disabled using the driver safety belt switch. The instrument cluster changes the state of the belt minder function if, within 60 seconds of first turning the ignition switch to position II, the driver safety belt is fastened and unfastened nine times. Successful completion of the change is indicated by a single chime and the safety belt warning indicator flashing five times, at 2 Hz. The belt minder function can also be enabled and disabled using T4. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sat Feb 07 2009 5:21am |
Bobby - if that works once again !!!!!!!! Tried it the old way (as per last RRS) and it didn't work - will try this!!
Sat Feb 07 2009 10:07am |
