Home > Technical > Am I paranoid or is my suspension or prop knocking?
mr_moped
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
I've had my 56 Plate RRS TDV6 for about a month, and ever since I've had it I have been concerned that there is a knocking coming from under the car if I went over a speed ramp or pot hole. Is there an explanation for this or should I be looking to waste my time trying to explain it to my local LR Stealer?
Thanks in advance,
Post #203001 Fri Jan 02 2009 6:17pm
Front or back of the car? 2005 Zambezi TDV6 - Gone but not forgotten
Post #203002 Fri Jan 02 2009 6:19pm
mr_moped
I think it's coming from the front.
Post #203003 Fri Jan 02 2009 6:20pm
Take it to the dealer and let them drive it - if there's a knocking when going over bumps it's probably something other than the talked about Dynamic Response knock. 2005 Zambezi TDV6 - Gone but not forgotten
Post #203005 Fri Jan 02 2009 6:23pm
Leo
Kenya
Could be the ball-joints ot suspension bushes. There is a new design of ball-joints, so if they are the problem, make sure the stealer uses the new ones. Thumbs Up
Post #203006 Fri Jan 02 2009 6:27pm
mr_moped
Just been reading about the Dynamic Response issue, to save me browsing through 100's of posts, was there ever a fix? or is the Stealer fobbing customers off with a white paper from LR?
I'm sure my problem is like the Dynamic Response one.
PS. The car has just had it's 45k service and nothing was noted about any issues.
Post #203008 Fri Jan 02 2009 6:32pm
http://www.rrsport.co.uk/forum/post203000.html#203000
Paulo has posted today (see second post from the bottom) with a potential fix
Post #203009 Fri Jan 02 2009 6:37pm
mr_moped
After reading "PauloAmore" response,
"In my case, 2 bushes 3 or 4" either side of the Dynamic Response unit. (maybe attached to the anti roll bar). - So nice to have a dealer that actually knows what the problem is and keeps trying to fix it."
Would these bushes be covered by the 3yr warranty?
PS. Would the stealer honour the warranty even if the car has been bought privately as i believe the LR stealer cannot tell if the RRS has been serviced at any other stealer franchise? They can only tell if the RRS has had any recalls.
Post #203011 Fri Jan 02 2009 7:30pm
rrsjo
Unnecessary quote removed
In the UK the bushes and their replacement are covered by the 3 yr warranty regardless of where you purchased the car Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #203093 Sat Jan 03 2009 10:55am
baxc
i have an 06 sport an it is booked into dealers for exactly the same problem sounds like its gona fall apart when you go over a pot hole this is the 3rd time its been in for this prob and everytime they replace the bushes its fine for a couple hundred mile then its back again hope you get it sorted m8
Post #203186 Sun Jan 04 2009 1:38am
mr_moped
baxc,
What has your dealer said they are going to do on your third visit?
Cheers,
Post #203347 Sun Jan 04 2009 8:08pm
baxc
ive booked it into a different dealers as my local 1 is closing down they arnt aware its been in b4 for this prob m8
Post #203368 Sun Jan 04 2009 10:59pm
mr_moped
Just introduced myself to my local dealer. As soon as I mentioned the words "knocking" and "RRS" to the service bloke he finished the sentence for me. It's booked in for this Thurs, he said they would need the car for a couple of days and offered me a loan vehicle for the duration.
He seemed to be very aware about the complaint owners have been making. As soon as I get the car back I shall write the results of what exactly has been replaced or modified.
Fingers crossed.
Post #203435 Mon Jan 05 2009 1:02pm
Excellent. You're lucky to have a dealer who isn't blind to the problem... plenty attempt to fob you off with the "it's a characteristic, sir" approach Thumbs Up
Post #203438 Mon Jan 05 2009 1:14pm
Good luck Thumbs Up RRS TDV6 Gone but still around
Post #203467 Mon Jan 05 2009 2:17pm
