![]() | Home > Maintenance & Modifications > Colour coding |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
sounds like he's doing it on the cheap......mine matches perfectly due to being well primed. |
BIRDY Member Since: 04 Nov 2006 Location: UK Posts: 213 ![]() ![]() ![]() |
He said he would remove the bumpers and trims to paint them and would rub them down.....maybe he was being over cautious just in case?? |
Sexy Pauly Member Since: 24 Aug 2008 Location: LAN DAN MATE Posts: 698 ![]() ![]() ![]() |
mine, is perfect, its hardwork as the bodyshop needs alot of work to be done to prep it, takes alot of time, adn thats why bodyshops would rather not do it than do it cheap!
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
mine was fast, well priced and is a perfect match. They just have to use body filler to smooth over the textureand make it smooth, it probably takes no more than two hours to do that, then they get painted. Its very simple.
