Home > Tips & Tricks > Open rear door...courtesy lights come on !!! |
geezo Member Since: 06 Nov 2006 Location: cardiff Posts: 14 |
THIS WAS IN REFERENCE TO SOME OFFERING TO EXPLAIN RE WIRING COURTESY LIGHTS TO COME ON WHEN OPENING REAR DOORS RRS HSE 06
Wed Feb 28 2007 8:49am |
Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285 |
Geezo..the link is here......
Wed Feb 28 2007 9:13am |
HOWS YOUR RRS RRS HSE 06
Wed Feb 28 2007 9:42am |
9 months old now....only done just over 3000 miles in it and it will be due for first service in 3 months time Arrived - RRSport 2016 HSE SDV6 HSE
Wed Feb 28 2007 9:47am |
had mine since last july, done 18,000 already.... seats are startin to move around a bit and sure i got some road noise in rear end even after i replaced tyres....
Wed Feb 28 2007 9:54am |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 |
looks fiddly, but well done Alan on the solution Brian, can't you come up with something just using a few bits of Velcro? RRS TDV6 Bluetooth, VR, Roof |
Wed Feb 28 2007 11:02am |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
Wed Feb 28 2007 11:19am |
gm28 Member Since: 21 Nov 2006 Location: Darlington Posts: 8 |
Sounds good, I'm a bit lazy so this weekends job is to jump a supply off the Load Space lamp (purple wire) into one courtesy lights, doing away with the green/white wire (+supply) and looping a wire through the headlining to the other courtesy lamp. Minimal trim removal this way. I will let u know if it works and post any pics that may help. |
Thu Mar 01 2007 1:00pm |
ivery819 Member Since: 16 Jan 2007 Location: -- Posts: 1241 |
Watch out for the headlining curtain srs and sensor ! |
Thu Mar 01 2007 1:29pm |
AlanM Member Since: 20 Feb 2007 Location: Victoria BC Posts: 88 |
I looked at this possibilty as it is simple on the right side. But the left side remains to be done, and I personally found it impossible to run a wire overhead behind the roofliner to the left courtesy light. (It might be possible floorwards.) Keep us all updated on your progress, please. I think the best way of all might well be to get a wiring diagram and see how physically close the courtesy light feed comes to the puddle light or cargo space light feed - they may well be in close proximity under the hood/bonnet, near the fuse box, or under the dash. . . . Come for a visit, Victoria is beautiful! |
Fri Mar 02 2007 7:18pm |
AlanM, I downloaded all the wiring diagrams to my work PC, will PM you a copy of the interior lighting on monday....see what you think. 06MY RRS 2.7 TDV6 HSE |
Fri Mar 02 2007 9:21pm |
rrsport2005 Member Since: 26 Nov 2007 Location: SYDNEY, AUSTRALIA Posts: 8 |
Hello Alan,
Mon Nov 26 2007 12:07pm |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
6 months between your reply and the one before! try this: http://rrsport.co.uk/forum/topic5550.html Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Mon Nov 26 2007 1:23pm |
Link is dead - anyone have the original documents? 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jan 14 2011 11:32am |
